How to Repair a Portable Fan
Views: 24K
View statistics:
Past 24 Hours:
13
Past 7 Days:
47
Past 30 Days:
246
All Time:
23,684
Comments: 6
2 comments on steps, 4 guide comments.
Go to guide comments
Completed: 6
6 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 - 20 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
This fix will restore your fan's original power and quiet operation. This fix does not require new parts, but does require a #1 Phillips head screwdriver, an 8mm wrench or socket, and a medium or low viscosity lubricant.
Tools
    1. How to Repair a Portable Fan, How to Repair a Portable Fan: step 1, image 1 of 2 How to Repair a Portable Fan, How to Repair a Portable Fan: step 1, image 2 of 2
      • Unplug the power cord before beginning.
      • Loosen the 4 phillips screws around the rim and remove the front of the cage
      Ask FixBot
    2. How to Repair a Portable Fan: step 2, image 1 of 1
      • Remove the fan blade by loosening the screw on the shaft while pulling up.
      • The screw does not need to be fully removed before the blade will slide free.
      Ask FixBot
    3. How to Repair a Portable Fan: step 3, image 1 of 1
      • Remove the wiring cover located above the fan motor.
      • There are 2 more screws holding the back mounting plate and cage together. They will be removed in a later step
      Ask FixBot
    4. How to Repair a Portable Fan: step 4, image 1 of 1
      • Remove the motor from the mounting plate by loosing the 2 smaller screws on the front.
      Ask FixBot
    5. How to Repair a Portable Fan: step 5, image 1 of 1
      • Remove the final 2 screws holding the mounting plate to the cage.
      Ask FixBot
    6. How to Repair a Portable Fan: step 6, image 1 of 1
      • Carefully pass the motor through the opening at the back of the cage.
      Ask FixBot
    7. How to Repair a Portable Fan: step 7, image 1 of 2 How to Repair a Portable Fan: step 7, image 2 of 2
      • Using an 8mm wrench and phillips screwdriver, remove the magnet mounts from the body of the motor.
      • The magnet will slide out of the motor . Inspect the magnet and motor for anything that may cause a hang-up.
      • Do not over-tighten the magnet mounts during reassembly. Over-tightening may cause the motor to bind.
      Ask FixBot
    8. How to Repair a Portable Fan: step 8, image 1 of 2 How to Repair a Portable Fan: step 8, image 2 of 2
      • Clean and lubricate the magnet shaft and mounting brackets
      • Any medium or low viscosity lubricant will do.
      Ask FixBot
To reassemble your device, follow these steps in reverse order.
6 other people completed this guide.
Isaac MacMillan
227 Reputation
1 Guide authored
4 Guide Comments
What are the chances the exact fan that I need to repair would be here? I'm about to put it back together… Let's see if it worked! 9/3/19, 10:45 pm.
Clark Nova - Reply Share
OK. It's back together but the fan doesn't spin. I feel the motor doing… Something. It vibrates softly. So, now to figure out why it's not spinning.
Mine did the same
Bellatrix moore (Bellatrix) - Reply Share
hello…my fan wouldn't work until I tilt the head upwards..what could be wrong pls???
adewale ogunbona - Reply Share
Past 24 Hours: 13
Past 7 Days: 47
Past 30 Days: 246
All Time: 23,684
