How to Repair a Patio Solar Light
    1. How to Repair a Patio Solar Light, How to Repair a Patio Solar Light: step 1, image 1 of 1
      • Disassemble the circuit box using a Phillips screwdriver.
      Ask FixBot
    2. How to Repair a Patio Solar Light: step 2, image 1 of 1
      • Using a multimeter, put the black wire in the COM port, and the red wire into the far right port. Set the switch to 20 volts DC.
      Ask FixBot
    3. How to Repair a Patio Solar Light: step 3, image 1 of 1
      • Remove battery from the port.
      • Check both ends of the battery with the multimeter.
      • The red prong touches the negative side, and the black prong touches the positive side of the battery.
      Ask FixBot
    4. How to Repair a Patio Solar Light: step 4, image 1 of 1
      • Ensure that the multimeter screen shows a number that matches or is greater than the voltage of the battery. If not, replace the battery.
      • Check the circuit board for detached, or loosely connected wires.
      Ask FixBot
    5. How to Repair a Patio Solar Light: step 5, image 1 of 3 How to Repair a Patio Solar Light: step 5, image 2 of 3 How to Repair a Patio Solar Light: step 5, image 3 of 3
      • Use a soldering iron at 400 Celsius to melt your soldering wire. Gather a droplet on the tip of the soldering iron, and use the drop to reattach the disconnected wire back onto the circuit board.
      • CAUTION: Don't handle metal parts of the soldering iron without proper gloves and protection.
      Ask FixBot
    6. How to Repair a Patio Solar Light: step 6, image 1 of 1
      • Turn your solar light back on before reassembling to test if it’s working properly.
      • When the light turns on, reassemble your solar light.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 10
Past 7 Days: 36
Past 30 Days: 133
All Time: 1,409
