How to Repair a Missing Crochet Stitch
    1. How to Repair a Missing Crochet Stitch, How to Repair a Missing Crochet Stitch: step 1, image 1 of 1
      • Identify where the repair is needed. Locate where the missing stitch should be.
      Ask FixBot
    2. How to Repair a Missing Crochet Stitch: step 2, image 1 of 1
      • Use the crochet hook to hook through the base stitch, (where the missing stitch should have been located), from front to back.
      Ask FixBot
    3. How to Repair a Missing Crochet Stitch: step 3, image 1 of 1
      • Create a slip knot with the yarn. Leaving about a 3 inch tail at the end to weave in later.
      Ask FixBot
    4. How to Repair a Missing Crochet Stitch: step 4, image 1 of 1
      • Loop the slip knot loop over the hook, and pull the yarn through the base stitch
      Ask FixBot
    5. How to Repair a Missing Crochet Stitch: step 5, image 1 of 1
      • Chain stitch the amount of stitches that the missing stitch should be plus one.
      • So if the missing stitch is a single crochet stitch, chain stitch two stitches, if the missing stitch is a double crochet stitch, chain stitch three stitches, and so on.
      Ask FixBot
    6. How to Repair a Missing Crochet Stitch: step 6, image 1 of 1
      • Remove the crochet hook and knot the remaining loop. Cut off the yarn leaving another 3 inch tail.
      Ask FixBot
    7. How to Repair a Missing Crochet Stitch: step 7, image 1 of 1
      • Thread the darning needle with one of the 3 inch tails. It does not matter which one you choose.
      • Caution: Needle is sharp and should be handled carefully to avoid injury.
      Ask FixBot
    8. How to Repair a Missing Crochet Stitch: step 8, image 1 of 1
      • Begin to weave the tail into the surrounding stitches from front to back.
      • Make sure to split the yarn when weaving, for a more seamless look.
      Ask FixBot
    9. How to Repair a Missing Crochet Stitch: step 9, image 1 of 1
      • After fully weaving one tail, cut off any excess, and begin weaving the next. Repeating Step 7 through 8.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 34
Past 30 Days: 116
All Time: 9,640
