How to Repair a Loose Embroidery Stitch
Views: 1.7K
View statistics:
Past 24 Hours:
Past 7 Days:
35
Past 30 Days:
126
All Time:
1,669
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 15 - 25 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
Have you noticed a snag or loose thread in one of your embroidery pieces? Don't get rid of it! This step-by-step guide will help you repair it. It is such an easy fix that only takes a few steps using the right tools.
Tools
    1. How to Repair a Loose Embroidery Stitch, How to Repair a Loose Embroidery Stitch: step 1, image 1 of 1
      • Gather all the necessary materials for your fix following these guidelines:
      • Pick the proper embroidery needle size. Lightweight fabrics can use a smaller needle, while heavyweight fabrics will need a larger needle.
      • Ensure that you pick a color of embroidery floss that matches the color of the thread you are trying to fix.
      • If using a lightweight fabric (e.g. cotton), use an embroidery hoop to stabilize the fabric.
      Ask FixBot
    2. How to Repair a Loose Embroidery Stitch: step 2, image 1 of 3 How to Repair a Loose Embroidery Stitch: step 2, image 2 of 3 How to Repair a Loose Embroidery Stitch: step 2, image 3 of 3
      • Embroidery floss consists of six different strands.
      • Separate the strands and decide how many you will need to thread.
      • Pull the strand(s) through the eye of the needle and ensure that the needle is in the center of the strand(s).
      • You should have double the amount of floss once threaded than when separated.
      Ask FixBot
    3. How to Repair a Loose Embroidery Stitch: step 3, image 1 of 3 How to Repair a Loose Embroidery Stitch: step 3, image 2 of 3 How to Repair a Loose Embroidery Stitch: step 3, image 3 of 3
      • To tie the floss, wrap the end around your pointer finger three times.
      • Slip the wrapped strands off your finger, and then pull the needle through the center.
      • Pinch your fingers where the longest part of the strand meets the wrapped portion and pull towards the end of the thread.
      • This should form a messy knot.
      Ask FixBot
    4. How to Repair a Loose Embroidery Stitch: step 4, image 1 of 2 How to Repair a Loose Embroidery Stitch: step 4, image 2 of 2
      • Pull the needle and thread through the fabric as close to the loose thread as possible.
      • Push the needle and thread down through the other end of the loose thread.
      • Repeat these steps 3 to 4 times going over the thread until it becomes flush with the rest of the embroidery pattern.
      • Be aware of where your hands are located while using the needle.
      Ask FixBot
    5. How to Repair a Loose Embroidery Stitch: step 5, image 1 of 1
      • To tie the anchor knot, push the needle and thread through an existing stitch or fabric hidden under the pattern. This should form a loop when you pull the needle.
      • Place your needle through that loop and pull to create an anchor knot.
      • Repeat this step 1-2 times to strengthen the knot.
      Ask FixBot
    6. How to Repair a Loose Embroidery Stitch: step 6, image 1 of 1
      • When the knot is finished, the thread should be completely flush with the rest of the embroidery pattern.
      Ask FixBot
    7. How to Repair a Loose Embroidery Stitch: step 7, image 1 of 1
      • To strengthen the embroidery you may use either fabric glue or a steamer. If you are using a lightweight fabric, make sure you use an embroidery hoop.
      • To use fabric glue, apply 1-2 drops everywhere that there is embroidery on the back of the fabric. Allow this to dry for at least 5 minutes.
      • If using a steamer, follow the instructions to turn it on for your particular model. Run the steamer over the back of the fabric two times. This will make the stitches taut.
      • Test the steamer first on the fabric in a hidden area before steaming to avoid staining or burning your work.
      Ask FixBot
Finish Line
Samantha Cook
145 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 35
Past 30 Days: 126
All Time: 1,669
