How to Repair a Large Wall Hole Using Drywall
    1. How to Repair a Large Wall Hole Using Drywall, How to Repair a Large Wall Hole Using Drywall: step 1, image 1 of 2 How to Repair a Large Wall Hole Using Drywall, How to Repair a Large Wall Hole Using Drywall: step 1, image 2 of 2
      • Measure the distance between the nearest studs on either side of the hole using a tape measure.
      • Trace a rectangular/square shape around the hole in pencil.
      • Use a box cutter to cut along the lines, making the hole into an even rectangular/square shape.
      Ask FixBot
    2. How to Repair a Large Wall Hole Using Drywall: step 2, image 1 of 1
      • Use the tape measure to measure the drywall to fit the dimensions of the hole trimmed in Step 1.
      • Cut out the section of drywall with the box cutter.
      Ask FixBot
      • Measure out the two pieces of wood using the tape measure. These strips of wood should be just a few inches longer than the length of the hole.
      • Cut the pieces of wood to the desired length with the hand saw.
      Ask FixBot
    3. How to Repair a Large Wall Hole Using Drywall: step 4, image 1 of 1
      • Place the two pieces of wood vertically inside the hole.
      • Use a Phillips flat head drill bit to drill 6x2 mm drywall screws into the two pieces of wood to the inside of the hole.
      Ask FixBot
    4. How to Repair a Large Wall Hole Using Drywall: step 5, image 1 of 2 How to Repair a Large Wall Hole Using Drywall: step 5, image 2 of 2
      • Place the section of drywall you cut in Step 2 into the hole.
      • The section of drywall should fit inside the hole snugly. The margins do not have to fit perfectly, but there should be no larger than a 1/8 inch gap between the dry wall and the edges of the hole.
      • Screw the drywall into the pieces of wood.
      • Make sure to screw in the corners of the drywall to ensure stability.
      Ask FixBot
    5. How to Repair a Large Wall Hole Using Drywall: step 6, image 1 of 1
      • Cut pieces of drywall mesh tape so that they will cleanly cover the gaps between the drywall and the hole.
      • Apply the pieces of dry wall mesh tape to the seams.
      Ask FixBot
    6. How to Repair a Large Wall Hole Using Drywall: step 7, image 1 of 1
      • Apply drywall filler over the mesh tape and the holes left by the screws using a putty knife.
      Ask FixBot
    7. How to Repair a Large Wall Hole Using Drywall: step 8, image 1 of 1
      • After the surface is completely dry, smooth out the wall with sandpaper.
      • Paint the wall the color of your choice.
      Ask FixBot
Finish Line
2 other people completed this guide.
Mustafa
169 Reputation
1 Guide authored
1 Guide Comment
Thanks for this detailed piece of information! I like this post.
Century Drywall - Reply Share
Past 24 Hours: 11
Past 7 Days: 76
Past 30 Days: 299
All Time: 4,443
