How to Repair a Hole in the Wall Using Spackle
    1. How to Repair a Hole in  the Wall Using Spackle, How to Repair a Hole in  the Wall Using Spackle: step 1, image 1 of 3 How to Repair a Hole in  the Wall Using Spackle, How to Repair a Hole in  the Wall Using Spackle: step 1, image 2 of 3 How to Repair a Hole in  the Wall Using Spackle, How to Repair a Hole in  the Wall Using Spackle: step 1, image 3 of 3
      • Prepare the damaged surface by cleaning and removing all dust and debris.
      • If the surface has a wallpaper, remove it for a length more extensive than the mesh patch.
      Ask FixBot
    2. How to Repair a Hole in  the Wall Using Spackle: step 2, image 1 of 3 How to Repair a Hole in  the Wall Using Spackle: step 2, image 2 of 3 How to Repair a Hole in  the Wall Using Spackle: step 2, image 3 of 3
      • Apply the self-Adhesive patch by peeling back the paper liner from the patch and apply it over the hole.
      • Press patch firmly to ensure a strong bond to the wall.
      Ask FixBot
    3. How to Repair a Hole in  the Wall Using Spackle: step 3, image 1 of 3 How to Repair a Hole in  the Wall Using Spackle: step 3, image 2 of 3 How to Repair a Hole in  the Wall Using Spackle: step 3, image 3 of 3
      • Open container and mix spackling compound before applying.
      • Mix thoroughly to have a smooth application.
      Ask FixBot
    4. How to Repair a Hole in  the Wall Using Spackle: step 4, image 1 of 3 How to Repair a Hole in  the Wall Using Spackle: step 4, image 2 of 3 How to Repair a Hole in  the Wall Using Spackle: step 4, image 3 of 3
      • Use the putty knife to spread spackling compound evenly over the adhesive patch.
      • Spread the spackling mixture beyond the area intended to cover.
      • Apply thinner layers toward the edges of the patch, so the patched area blends with the wall.
      Ask FixBot
    5. How to Repair a Hole in  the Wall Using Spackle: step 5, image 1 of 2 How to Repair a Hole in  the Wall Using Spackle: step 5, image 2 of 2
      • Allow the compound to dry completely before moving to the last step.
      • Depending on the hole's size and thickness of the layers applied, it might take a while to dry.
      Ask FixBot
    6. How to Repair a Hole in  the Wall Using Spackle: step 6, image 1 of 3 How to Repair a Hole in  the Wall Using Spackle: step 6, image 2 of 3 How to Repair a Hole in  the Wall Using Spackle: step 6, image 3 of 3
      • Once the spackling compound has dried, sand it lightly with a sand pad/sponge.
      • Smooth out any bumps on the surface.
      • Do not sand down to mesh patch.
      • Once the surface is smooth, paint, wallpaper, or apply any texture desire.
      Ask FixBot
2 other people completed this guide.
Kerticia Miller
205 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 7
Past 7 Days: 49
Past 30 Days: 203
All Time: 8,268
