How to Repair a Frayed Headphone Cable
Views: 131K
View statistics:
Past 24 Hours:
32
Past 7 Days:
158
Past 30 Days:
722
All Time:
131,393
Comments: 7
4 comments on steps, 3 guide comments.
Go to guide comments
Completed: 44
44 people have marked this guide "completed." Will you be next?
Favorites: 34
34 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 - 25 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
Tired of replacing old headphone sets? Here’s a step-by-step guide on repairing frayed headphone cables in an environmentally efficient and affordable way. This guide will require soldering skills.
Parts
Tools
    1. How to Repair a Frayed Headphone Cable, Cable: step 1, image 1 of 2 How to Repair a Frayed Headphone Cable, Cable: step 1, image 2 of 2
      • Cut above the frayed portion of the cable using wire cutters.
      • Using the wire cutters, strip away approximately one inch of wire coating.
      • Use caution to avoid cutting too far into the wire.
      Ask FixBot
    2. How to Repair a Frayed Headphone Cable: step 2, image 1 of 2 How to Repair a Frayed Headphone Cable: step 2, image 2 of 2
      • After stripping the wire, four wires should be exposed. The wires should be three different colors.
      • Red: Right channel
      • Gold/copper: Ground
      • Blue/green: Left channel
      • Twist the two ground wires together.
      Ask FixBot
    3. How to Repair a Frayed Headphone Cable: step 3, image 1 of 2 How to Repair a Frayed Headphone Cable: step 3, image 2 of 2
      • Unscrew the plug housing.
      • Thread the wire through the plug housing.
      Ask FixBot
    4. How to Repair a Frayed Headphone Cable: step 4, image 1 of 1
      • Remove the enamel from the red and blue wires with a wire stripper.
      Ask FixBot
    5. How to Repair a Frayed Headphone Cable: step 5, image 1 of 1
      • With a soldering iron, apply a small amount of solder to the end of each wire.
      • This is especially important for the twisted ground wires; the solder should hold them together.
      Ask FixBot
    6. How to Repair a Frayed Headphone Cable: step 6, image 1 of 3 How to Repair a Frayed Headphone Cable: step 6, image 2 of 3 How to Repair a Frayed Headphone Cable: step 6, image 3 of 3
      • Thread the wires through each hole and wrap them back over.
      • See the third picture for a diagram of where each wire goes.
      • Next, twist each wire with itself to secure it to the lead. This can be seen in the second picture.
      Ask FixBot
    7. How to Repair a Frayed Headphone Cable: step 7, image 1 of 2 How to Repair a Frayed Headphone Cable: step 7, image 2 of 2
      • Solder over each lead's hole, connecting the wire to the lead.
      • Your solder joints should completely cover the hole and surround the wire.
      • After each wire is connected, use a drop of hot glue to secure the wires and prevent them from touching each other.
      Ask FixBot
    8. How to Repair a Frayed Headphone Cable: step 8, image 1 of 1
      • Screw the housing back onto the jack and test your work.
      • If the sound turns on and off this is a connection error. To fix it, look at your solder joints and make sure the wires are fully connected to the leads. If not, apply more solder to the joints, covering the wire.
      Ask FixBot
Finish Line
44 other people completed this guide.
Tyler
971 Reputation
1 Guide authored
Cal Poly, Team 23-2, Green Winter 2015 Member of Cal Poly, Team 23-2, Green Winter 2015
CPSU-GREEN-W15S23G2
4 Members
48 Guides authored
3 Guide Comments
To me, the more difficult part in this job, is solder.... Now, If you are not sure, with where solder each wire, try with a tester in the continuity mode, and test between the each part of the tip and the three holes. Greetings!
Anderson Barreto - Reply Share
great instruction - any for repair of cable with microphone ? and even a flat cable ?
LiveVest - Reply Share
Air phone ke andar plate lagi rahti hai bye Tut gaye
Deepak Sutar - Reply Share
Past 24 Hours: 32
Past 7 Days: 158
Past 30 Days: 722
All Time: 131,393
