How to Repair a Frayed Dell AC Adapter Cable
Views: 78K
View statistics:
Past 24 Hours:
6
Past 7 Days:
41
Past 30 Days:
210
All Time:
78,045
Comments: 2
1 comment on steps, 1 guide comment.
Go to guide comments
Completed: 29
29 people have marked this guide "completed." Will you be next?
Favorites: 37
37 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 45 minutes - 1 hour
Difficulty: Moderate
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Introduction
Go to step 1 ↓
Use this guide to repair a power supply cable that has frayed at the power inlet.
Parts
  • Wire
    Needed only if the old wires can not be rejoined.
Tools
    1. How to Repair a Frayed Dell AC Adapter Cable, How to Repair a Frayed Dell AC Adapter Cable: step 1, image 1 of 3 How to Repair a Frayed Dell AC Adapter Cable, How to Repair a Frayed Dell AC Adapter Cable: step 1, image 2 of 3 How to Repair a Frayed Dell AC Adapter Cable, How to Repair a Frayed Dell AC Adapter Cable: step 1, image 3 of 3
      • Be sure to unplug the power supply from the wall before doing any work to prevent electric shock.
      • Inspect the frayed power supply end for spots that you can cut off the connector insulation without damaging the wires.
      • Cut the insulation off the connector using wire cutters, scissors, or a sharp knife.
      Ask FixBot
    2. How to Repair a Frayed Dell AC Adapter Cable: step 2, image 1 of 3 How to Repair a Frayed Dell AC Adapter Cable: step 2, image 2 of 3 How to Repair a Frayed Dell AC Adapter Cable: step 2, image 3 of 3
      • There will be two wires in the connector. One wire comes from the inner cable and the other comes from the frayed outer cable. Find the wire associated with the frayed outer cable.
      • Use a small sharp knife, such as hobby knife, to cut the wire free of the plastic casing.
      • Be sure not to cut or damage the wire.
      Ask FixBot
    3. How to Repair a Frayed Dell AC Adapter Cable: step 3, image 1 of 3 How to Repair a Frayed Dell AC Adapter Cable: step 3, image 2 of 3 How to Repair a Frayed Dell AC Adapter Cable: step 3, image 3 of 3
      • Inspect the wires and determine if there are enough strands that can be soldered together to make a safe, reliable connection.
      • If you can make a good connection with the old wires, press them together so there are no strands fraying outward.
      • If there are only a couple wires still connected and the severed ends can not reach each other, or the wire is completely severed, you will need to splice in some new wire.
      Ask FixBot
    4. How to Repair a Frayed Dell AC Adapter Cable: step 4, image 1 of 2 How to Repair a Frayed Dell AC Adapter Cable: step 4, image 2 of 2
      • Solder the old, or new, wires together, making sure that the solder flows a little past the damaged area.
      • Re-settle the wire back into the white casing as best as possible.
      Ask FixBot
    5. How to Repair a Frayed Dell AC Adapter Cable: step 5, image 1 of 3 How to Repair a Frayed Dell AC Adapter Cable: step 5, image 2 of 3 How to Repair a Frayed Dell AC Adapter Cable: step 5, image 3 of 3
      • Open the Sugru pack, remove the material, and press it around the connector to make a new connector insulator. It is recommended that your new sheath extends at least .5" past the damaged area.
      • You have approximately 30 minutes to work the Sugru. Then allow about 24 hours for it to fully cure.
      Ask FixBot
Finish Line
29 other people completed this guide.
Phillip Takahashi
88,111 Reputation
87 Guides authored
1 Guide Comment
What do you mean by splicing new wire when completely severed?
K Caye - Reply Share
Past 24 Hours: 6
Past 7 Days: 41
Past 30 Days: 210
All Time: 78,045
