Introduction
If you have a favorite outfit or item with a jammed zipper and don't have time to replace it, don't worry! This guide demonstrates a technique to fix old zippers using a bar of soap.
Before using this guide, check your clothing for flaws near the zipper, such as tears or loose threads.
Look at the zipper to check if the fabric is stuck in the track or if the zipper is the problem before you begin the fix.
1 Guide Comment
A pair of pliers that I believe are called Rebar pliers is easier to use when tightening the glider. That is because the material often is quite thick and a straight nosed plier is held apart by it if the glider is not very big, on the side away from the opening. On the open side it is no problem.
