How to Repair Nylon Shorts
Views: 4.2K
View statistics:
Past 24 Hours:
3
Past 7 Days:
32
Past 30 Days:
142
All Time:
4,193
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 20 minutes
Difficulty: Moderate
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Introduction
Go to step 1 ↓
If you find a tear in your nylon shorts, use this guide to stitch the rip. Tears in the seam are easy to fix and can prolong the life of your favorite clothing. (Seams are two pieces of fabric joined together with stitching.) You do not have to be a seamstress to be able to mend your shorts— you will only need a needle and thread.
Tools
    1. How to Repair Nylon Shorts, How to Repair Nylon Shorts: step 1, image 1 of 1
      • Be sure to choose a thread color that is similar to the garment you are repairing.
      • Thread the needle by stringing the thread through the eye of the needle.
      • Knot the end of the thread and cut off any excess thread. The knot should be large enough to catch the fabric and not pull through.
      Ask FixBot
    2. How to Repair Nylon Shorts: step 2, image 1 of 1
      • Take the torn seam into both hands, and overlap one side with the other until both sides are aligned.
      Ask FixBot
    3. How to Repair Nylon Shorts: step 3, image 1 of 1
      • Starting from the inside of the garment, pull the needle through the fabric.
      • Pull the thread until the knot catches the fabric.
      Ask FixBot
    4. How to Repair Nylon Shorts: step 4, image 1 of 1
      • Make small stitches along the length of the rip.
      • Do not pull the thread too tight or it will cause rippling in the fabric.
      Ask FixBot
    5. How to Repair Nylon Shorts: step 5, image 1 of 1
      • Tie the thread as close to the fabric as possible.
      • Cut off any extra thread that is still attached.
      Ask FixBot
This guide can be applied to any piece of clothing that has a rip in the seam. Happy stitching!
Rachel Brockett
145 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 32
Past 30 Days: 142
All Time: 4,193
