Featured Student Guide
This guide has been the hard work of our awesome students and is found to be exceptionally cool by the iFixit staff.
Introduction
Go to step 1 ↓If you have areas of damage in your baseboards or crown molding, this guide describes a fast fix in a few simple steps. You’ll need tools you likely have around your home. We will waterproof exposed wood with wood glue, build up the areas with wood filler, sand, and touch up the damaged areas so they look like new. This guide is for areas of damage where full sections of lumber are not needed to be replaced.
Before beginning, be sure to become familiar with the primary products - wood glue and wood filler. Some products contain warnings about skin exposure which you’ll want to be aware of when choosing your tools.
While the time estimate is 2-4 hours, much of that is waiting for the product to dry. You can certainly accomplish this project with large breaks in that time.
Tools
Sand the damaged area with the 120 grit sandpaper or a sanding block.
Use a utility knife to smooth rougher areas if needed.
Clean-up should be a breeze, and you should be ready to finish your weekend with loads of time to spare after this simple project!
2 other people completed this guide.
