How to Repair Frayed Shoelaces
    1. How to Repair Frayed Shoelaces, How to Repair Frayed Shoelaces: step 1, image 1 of 1
      • Cut of the excess frayed shoelace.
      Ask FixBot
    2. How to Repair Frayed Shoelaces: step 2, image 1 of 3 How to Repair Frayed Shoelaces: step 2, image 2 of 3 How to Repair Frayed Shoelaces: step 2, image 3 of 3
      • Slip the entire heat shrink tube over the frayed part of the lace.
      • Make sure to clump the frayed part of the lace together when inserting the tubing.
      • Do not cover too much of the lace that is not frayed with tubing as that could result in unwanted indents in the shoelace.
      Ask FixBot
    3. How to Repair Frayed Shoelaces: step 3, image 1 of 2 How to Repair Frayed Shoelaces: step 3, image 2 of 2
      • After slipping the tube on, grab the scissors and trim the excess tubing to the length of your satisfaction.
      • Remember not to go beyond the frayed part of the lace with tubing.
      Ask FixBot
    4. How to Repair Frayed Shoelaces: step 4, image 1 of 3 How to Repair Frayed Shoelaces: step 4, image 2 of 3 How to Repair Frayed Shoelaces: step 4, image 3 of 3
      • Now use the lighter and heat the heat shrink tube, about an inch away from the lace, until the tube becomes compressed all the way around.
      • Make sure to heat the heat shrink tube all the way around, heating the entire tube
      • When heating, always keep moving the lighter all around and not staying on one part of the tube for too long.
      Ask FixBot
    5. How to Repair Frayed Shoelaces: step 5, image 1 of 1
      • Repeat these steps on all the other frayed shoelaces.
      Ask FixBot
When the heat shrink tube is completely shrunk to appropriate size, you are finished. Repeat steps 1-4 depending on how many frayed laces are present.
14 other people completed this guide.
Anirudh Jain
605 Reputation
1 Guide authored
Cal Poly, Team 28-6, Green Spring 2015 Member of Cal Poly, Team 28-6, Green Spring 2015
CPSU-GREEN-S15S28G6
4 Members
48 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 21
Past 30 Days: 73
All Time: 13,062
