How to Repair Dried Out Liquid Lipstick
  1. How to Repair Dried Out Liquid Lipstick, How to Repair Dried Out Liquid Lipstick: step 1, image 1 of 1
    • Fill a bowl full of warm to hot water and place off to the side for later.
    Ask FixBot
  2. How to Repair Dried Out Liquid Lipstick: step 2, image 1 of 1
    • Tighten the cap on the liquid lipstick to prevent water from going inside while the lipstick is submerged in the bowl of water.
    Ask FixBot
  3. How to Repair Dried Out Liquid Lipstick: step 3, image 1 of 1
    • Take one pipe cleaner and wrap it all the way around the seal of the liquid lipstick cap to help prevent water from entering the lipstick.
    • Wrap a second pipe cleaner one to two times around the first pipe cleaner.
    • Make sure you leave enough length on either side of the pipe cleaner so that it can hang onto the sides of the bowl.
    Ask FixBot
  4. How to Repair Dried Out Liquid Lipstick: step 4, image 1 of 1
    • Submerge the liquid lipstick into the warm water.
    • Make sure both ends of the pipe cleaner are leaning on the sides of the bowl to keep the liquid lipstick upright in the water.
    • Leave the liquid lipstick in the water for 25-30 minutes.
    Ask FixBot
  5. How to Repair Dried Out Liquid Lipstick: step 5, image 1 of 1
    • After the 25-30 minutes are up, remove the liquid lipstick.
    • Shake the liquid lipstick tube to make sure the lipstick has liquified again or you can take the wand and mix it around inside of the tube instead.
    Ask FixBot
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 12
Past 30 Days: 54
All Time: 1,593
