How to Repair Black screen of death
      • Cleaning the pins on the games and console game pin connector. Dirt may clog them up over time, preventing the system from working.
      • You will need rubbing alcohol and a q-tip. If you dont have one use water and a credit card with a cloth on it.
      • Wedge the q-tip or credit card into the ports. If the q-tip can't fit take some of the fuzz off.
      Ask FixBot
      • Some cables may not work after a few years. If you notice the power cable being sensitive to movement it may require replacement. Also try doing the same as you did with the game pins to the AV port and AV cable pins.
      Ask FixBot
      • Some games i have seen now working because of corrosion and you need to try another game.
      Ask FixBot
      • Take out the booster or expansion pack with the n64 on for 10 seconds then put it back in and try to turn it off and on!
      Ask FixBot
2 other people completed this guide.
Bobby gunnels
419 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 44
Past 30 Days: 114
All Time: 2,760
