Introduction
Before starting this repair, note that Apple doesn’t support SSD swaps or upgrades at this time.
This guide shows how to remove one or both SSD modules in your Mac Studio (2023).
If you choose to continue with this repair, be sure to backup your Mac with Time Machine.
Completely shut down your Mac Studio.
Unplug all cables from your device.
Flip your Mac Studio over and lay it down so the bottom faces up and the SD card slot and two front USB‑C ports are facing you.
Heat an iOpener and lay it over one of the bottom cover screws for two minutes to soften the adhesive near the screw—this is where you'll insert a spudger in the next step.
Insert the point of a spudger under the pad's inner edge, near the screw you applied heat to in the previous step.
Use the spudger to lift the pad and separate the adhesive.
Insert the flat end of a spudger under the pad.
Slide the spudger under the entire pad to separate the remaining adhesive.
Tool used on this step:Tesa 61395 Tape$2.95
If the adhesive strips are still sticky, you can reuse them.
Use the flat end of a spudger and your fingers to scrape up and remove the old adhesive strips.
Use isopropyl alcohol and a microfiber cloth to remove the old adhesive residue.
Apply the new adhesive strips to the bottom cover and remove their liners.
Firmly press the bottom cover screw pad into its recess to secure it.
Tool used on this step:FixMat$36.95
Use a T10 Torx screwdriver to remove the four 8 mm‑long screws securing the bottom cover.
Insert the point of a spudger in one of the bottom cover's ventilation holes and lift the cover until you can grab it with your fingers.
Remove the bottom cover.
Use a T10 Torx screwdriver to remove the six screws securing the power supply:
Four 6 mm‑long screws
Two 7 mm‑long screws with washers
Flip your Mac Studio around so the rear ports are facing you.
Firmly hold the power supply with one hand and lift up the edge near the power cord port.
With your free hand, pinch the head of the power cord port connector to unclip it and pull straight down to disconnect the cable.
Carefully tilt the power supply away from the power cord port so it's at a 90-degree angle.
Keep the power supply tilted up for the next step.
With your free hand, pinch the head of the power supply connector to unclip it and pull straight away from the socket to disconnect the cable.
Flip your Mac Studio around so the SD card reader and two front USB‑C ports are facing you.
Use a T6 Torx screwdriver to remove the eight screws securing the internal frame:
Seven 5 mm‑long screws
One 4 mm‑long screw
Slowly lift the internal frame straight up and remove it, making sure no cables get snagged.
SSD SLEEVE?
Use a T8 Torx screwdriver to remove the 3.8 mm‑long screw(s) securing the SSD(s).
Wiggle the SSD side-to-side while pulling it away from the socket to loosen it.
Restore your Mac from a backup after reassembly.
2 Guide Comments
Thanks for the interesting article. You said: "Your Mac Studio will have one or two SSDs depending on its storage configuration".
Does it mean it uses Redundant Array of Independent Disks (RAID) 0, or Just a Bunch Of Disks (JBOD)? In either case, that would mean more than twice the probability of storage failure (compared to a single SSD), since when one SSD fails, the other SSD fails, or the controller fails, all date will be lost. Not good!!!
512GB, 1TB and 2TB configurations have just a single SSD module, the ones with higher capacity have 2 of those. this essentially means those are similar to RAID0/striping - just like it is with the soldered-on storage of MBP: the data is interleaved across the flash chips. I'd say the striping is used to boost the performance only. there are 4TB and 8TB configurations, which would imply that there's a 4TB module that could be also used "alone" to get 4 TB of internal storage. but apple preferred to go with 2+2 and 4+4TB configurations to double the media access bandwidth. these are essentially just bare flash chips (the SSD controller resides in the CPU complex - previously it was in the T2 chip) soldered on a PCB with a few passive components and regulators.
