How to Remove a Stuck Wash Plate from an LG Washing Machine
Video Guide
This guide was transcribed from a YouTube video.
    • Feel around the pulsator cap to find the small opening for a screwdriver tip.
    • Use a small 2.5 mm flathead screwdriver to pry up the cap and remove it.
    • Set the cap aside and clean it, because the area underneath is usually extremely dirty.
    Ask FixBot
    • Use a 10 mm socket wrench to remove the bolt that holds the wash plate to the main shaft.
    • Hold the wash plate down with one hand while loosening the bolt if the plate is worn and wants to spin.
    Ask FixBot
    • Pick two screws that fit the holes in the wash plate and can thread into the plate material.
    • Avoid #10 screws because they are too large, and avoid #6 screws because they are too small.
    • Use #8 screws with coarse threads and a sharp point so they can stab through the metal and plastic easily.
    • Use #8 deck screws, because they thread into the wash plate holes with less effort than other screw types tested.
    • Use 1 inch screws, or use 3/4 inch screws as an alternative length.
    Ask FixBot
    • Thread the two screws into the wash plate holes until they bite and hold firmly.
    • Apply force as needed to get the screws to start threading, because it can take pressure to make them bite.
    • Stop threading before the screws go too far past the bottom of the wash plate.
    • Don’t bury the screws into the plastic tub, because puncturing the tub could cause a leak.
    • Expect the wash plate to move a bit while you thread the screws, and keep working until both screws are secure.
    Ask FixBot
    • Use slip-joint pliers to grip both screw heads so you can lift straight up on the wash plate.
    • Pull up as hard as you can on the screws until the wash plate pops loose.
    • Keep pulling if it doesn’t release right away, because this method can also work on extremely difficult wash plates.
    Ask FixBot
    • Remove the screws from the wash plate after the plate comes free.
    • Inspect the screw holes for metal burrs created by the screws if you plan to reuse the same wash plate.
    • Smooth down any burrs with sandpaper before reinstalling the wash plate.
    Ask FixBot
    • Clean the wash plate if you plan to reuse it, because there may be dirt under the cap and debris on the underside.
    Ask FixBot
    • Push the wash plate back into place on the shaft.
    • Reinstall the center bolt.
    • Press the cap back into place to finish.
    Ask FixBot
Reinstall the wash plate and center bolt securely before running a rinse or spin test. Repair didn't go as planned? Ask our Answers community for help.
Ben Schlichter
6,557 Reputation
224 Guides authored
0 Guide Comments
Past 24 Hours: 16
Past 7 Days: 93
Past 30 Days: 326
All Time: 1,038
