Introduction
Go to step 1 ↓This guide will show you how to extract a screw that has broken while being embedded inside its hole, along with showing you how to replace it with a new one. This process works for screws inside walls, pieces of lumber, or metal. The guide requires a couple of power tools, so you should always use the necessary precautions when using them to avoid any injuries.
Tools
Use an angle grinder to grind the tip of the broken screw until its surface is smooth and even.
4 other people completed this guide.
1 Guide Comment
It all sounds great, but... It didn't work. I have a Porter-Cable older router. The first screw in the base came out without a problem, and the other 2 screws wouldn't budge. I tried various penetrating oils and nothing. I drilled one of the screws and tried an extractor...nothing. I cut off the screw and drilled clean through, then tried the extractor again...nothing. So, what's left of the screw is drilled out, won't budge with a hole, and is laughing at me.
Although I haven't tried it yet, I was going to cut of the base, leaving the screw intact, getting some vise grips and try to twist it out.
Any other ideas??
