How to Remove a Blood Stain from Satin
    1. How to Remove a Blood Stain from Satin, How to Remove a Blood Stain from Satin: step 1, image 1 of 2 How to Remove a Blood Stain from Satin, How to Remove a Blood Stain from Satin: step 1, image 2 of 2
      • Dip the stained fabric in bowl of cold water.
      • Massage the stain while submerged for about 20 seconds to ensure that it is fully saturated.
      Ask FixBot
    2. How to Remove a Blood Stain from Satin: step 2, image 1 of 1
      • Pour laundry detergent or dish soap into bowl.
      • Amount poured should equate to approximately 1/2 cup (120ml). Larger stains may require higher quantities.
      Ask FixBot
    3. How to Remove a Blood Stain from Satin: step 3, image 1 of 2 How to Remove a Blood Stain from Satin: step 3, image 2 of 2
      • Wet a clean, dry cloth or sponge in the bowl.
      Ask FixBot
    4. How to Remove a Blood Stain from Satin: step 4, image 1 of 2 How to Remove a Blood Stain from Satin: step 4, image 2 of 2
      • Dab the stain gently by repeatedly pressing the wet cloth or sponge against it.
      • Rubbing the stain may further spread it and/or embed it deeper in the fabric.
      Ask FixBot
    5. How to Remove a Blood Stain from Satin: step 5, image 1 of 2 How to Remove a Blood Stain from Satin: step 5, image 2 of 2
      • Rinse the stain with cold water.
      • Inspect to determine whether further cleaning is required.
      Ask FixBot
    6. How to Remove a Blood Stain from Satin: step 6, image 1 of 1
      • Add a few drops of vinegar or hydrogen peroxide to the initial solution if the stain persists.
      • Repeat steps 3 and 4.
      • The combination of these chemicals creates peracetic acid. Do not mix hydrogen peroxide and vinegar.
      Ask FixBot
    7. How to Remove a Blood Stain from Satin: step 7, image 1 of 1
      • Rinse the garment in a bowl of clean water.
      Ask FixBot
Repeat as needed until the stain is gone.
Malak Elsayed Elghobashy
145 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 11
Past 7 Days: 42
Past 30 Days: 113
All Time: 1,711
