How to Remove Tarnish from a Pandora Bracelet
  1. How to Remove Tarnish from a Pandora Bracelet, How to Remove Tarnish from a Pandora Bracelet: step 1, image 1 of 3 How to Remove Tarnish from a Pandora Bracelet, How to Remove Tarnish from a Pandora Bracelet: step 1, image 2 of 3 How to Remove Tarnish from a Pandora Bracelet, How to Remove Tarnish from a Pandora Bracelet: step 1, image 3 of 3
    • Take your bracelet and find the barrel clasp at the bottom.
    • Remove any charms on your bracelet and place them separately (they can also be cleaned if applicable).
  2. How to Remove Tarnish from a Pandora Bracelet: step 2, image 1 of 1
    • Grab any small bowl and place a medium sized sheet of aluminum foil over it.
    • Place your bracelet into the aluminum-covered bowl.
  3. How to Remove Tarnish from a Pandora Bracelet: step 3, image 1 of 2 How to Remove Tarnish from a Pandora Bracelet: step 3, image 2 of 2
    • Heat 1 cup of water in the microwave for 2 minutes.
    • Add that cup of hot water to your aluminum covered bowl.
    • Water can be superheated in the microwave. Be sure to stay within the recommended time limit.
  4. How to Remove Tarnish from a Pandora Bracelet: step 4, image 1 of 2 How to Remove Tarnish from a Pandora Bracelet: step 4, image 2 of 2
    • Add ¼ teaspoon of baking soda into your bowl with the hot water and bracelet.
    • Mix the baking soda until it is dissolved into your bowl completely.
  5. How to Remove Tarnish from a Pandora Bracelet: step 5, image 1 of 1
    • Let your bracelet sit in the baking soda for 3 minutes.
  6. How to Remove Tarnish from a Pandora Bracelet: step 6, image 1 of 1
    • After 3 minutes, scrub your bracelet entirely with a small scrub brush.
  7. How to Remove Tarnish from a Pandora Bracelet: step 7, image 1 of 2 How to Remove Tarnish from a Pandora Bracelet: step 7, image 2 of 2
    • After scrubbing, grab a towel and dry the bracelet entirely.
    • Make sure to dry the inside of the barrel clasp to prevent future tarnish build up.
  8. How to Remove Tarnish from a Pandora Bracelet: step 8, image 1 of 1
    • The bracelet is now free of tarnish!
Finish Line
Michelle Ambriz
157 Reputation
1 Guide authored
1 Guide Comment
Can a stainless steel pot or glass bowl be used if a person doesn’t have aluminum foil
Harley - Reply Share
Past 24 Hours: 16
Past 7 Days: 165
Past 30 Days: 665
All Time: 8,310
