How to Remove Stains from Plastic Food Containers
View statistics:
Past 24 Hours:
2
Past 7 Days:
38
Past 30 Days:
139
All Time:
285
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 1 hour
Difficulty: Easy
Introduction
Go to step 1 ↓
This guide demonstrates how to remove stubborn stains from plastic storage containers. The technique works for containers of any size; just adjust the amount of baking soda and water as needed to coat the stained areas.
    1. How to Remove Stains from Plastic Food Containers, How to Remove Stains from Plastic Food Containers: step 1, image 1 of 1
      • Add 2 tablespoons of baking soda to the bottom of the container so it coats the inside.
      Ask FixBot
    2. How to Remove Stains from Plastic Food Containers: step 2, image 1 of 1
      • Slowly add in warm water and stir until the solution becomes similar to the consistency of toothpaste.
      Ask FixBot
    3. How to Remove Stains from Plastic Food Containers: step 3, image 1 of 1
      • Once you get the right consistency, spread the solution over the stained area of the container.
      Ask FixBot
    4. How to Remove Stains from Plastic Food Containers: step 4, image 1 of 1
      • Place the container outside in direct sunlight for at least 30 minutes.
      • For better results, leave the container out for longer to let the solution soak into the stain.
      • This process may not completely remove the stains, but it can help reduce them.
      Ask FixBot
    5. How to Remove Stains from Plastic Food Containers: step 5, image 1 of 1
      • Give it one final scrub with the paste still inside the container.
      Ask FixBot
    6. How to Remove Stains from Plastic Food Containers: step 6, image 1 of 1
      • Wash the container with dish soap and water.
      Ask FixBot
This won't fully remove the stain, but it will help remove the base layer. The reason plastic containers like this stain so badly is that the natural dyes and acids in our food eat away the plastic.
Robyn Brough
133 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 38
Past 30 Days: 139
All Time: 285
