Up to 20% off select tools
How to Remove Rust on Car Body
Views: 5.7K
View statistics:
Past 24 Hours:
8
Past 7 Days:
50
Past 30 Days:
267
All Time:
5,743
Comments: 2
1 comment on steps, 1 guide comment.
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 30 minutes
Difficulty: Moderate
Better Introduction
Improve this guide by completing or revising its introduction.
Introduction
Go to step 1 ↓
This is a tutorial on how to get rid of rust that lies on the car frame. Getting the rust off the car will prevent it from further damage and rusting.
    1. How to Remove Rust on Car Body, How to Remove Rust on Car Body: step 1, image 1 of 2 How to Remove Rust on Car Body, How to Remove Rust on Car Body: step 1, image 2 of 2
      • Spray down the rust with a spray bottle mixed with water and dish soap.
      • Wipe the mixture with a microfiber cloth.
      Ask FixBot
    2. How to Remove Rust on Car Body: step 2, image 1 of 3 How to Remove Rust on Car Body: step 2, image 2 of 3 How to Remove Rust on Car Body: step 2, image 3 of 3
      • Pour a small amount of rubbing alcohol onto a microfiber cloth.
      • Clean the rusted area with the cloth to remove any contaminants.
      Ask FixBot
    3. How to Remove Rust on Car Body: step 3, image 1 of 3 How to Remove Rust on Car Body: step 3, image 2 of 3 How to Remove Rust on Car Body: step 3, image 3 of 3
      • Rub the rusted area with 80-grit sandpaper until you start seeing the bare metal.
      Ask FixBot
    4. How to Remove Rust on Car Body: step 4, image 1 of 2 How to Remove Rust on Car Body: step 4, image 2 of 2
      • Rub the rusted area with 220-grit sandpaper until all of the rust is removed.
      • Dampen a cloth with soapy water and wipe down the sanded area.
      Ask FixBot
    5. How to Remove Rust on Car Body: step 5, image 1 of 2 How to Remove Rust on Car Body: step 5, image 2 of 2
      • This step is to prepare your spot for spray painting.
      • Add some paper around the areas you do not want paint on. Make sure you go a little past where you are going to spray paint to blend the paint into the surrounding area.
      Ask FixBot
    6. How to Remove Rust on Car Body: step 6, image 1 of 3 How to Remove Rust on Car Body: step 6, image 2 of 3 How to Remove Rust on Car Body: step 6, image 3 of 3
      • Spray three even coats of primer, waiting at least five minutes between each coat.
      • Let the third coat sit for 15 minutes.
      Ask FixBot
    7. How to Remove Rust on Car Body: step 7, image 1 of 3 How to Remove Rust on Car Body: step 7, image 2 of 3 How to Remove Rust on Car Body: step 7, image 3 of 3
      • Spray three even coats of paint on top of the primer, waiting five minutes between each coat.
      • You can either use a color similar to your car or you can get the actual color of you car by looking for the car's color code.
      • After the final coat, wait 24 hours before removing the surrounding paper.
      Ask FixBot
Finish Line
3 other people completed this guide.
Author
with
Robert Gutierrez
199 Reputation
1 Guide authored
1 Guide Comment
Good guide, also recommending ChrisFix's video relating to this: https://www.youtube.com/watch?v=n4vusY2-...
Fixing Person - Reply Share
Past 24 Hours: 8
Past 7 Days: 50
Past 30 Days: 267
All Time: 5,743
