Tools
Introduction
Go to step 1 ↓Grease buildup can reduce the performance and appearance of stainless steel cookware. This guide shows you how to remove burnt-on grease. You can use common household items like dish soap, baking soda, white vinegar, and a non-scratch sponge. This process is easy for beginners. It helps restore your cookware without harming the stainless steel surface. Wear rubber gloves if you have sensitive skin, and avoid using steel wool or abrasive scrubbers because they may scratch the cookware.
Inspect the cookware to identify areas with heavy grease buildup.
Your stainless steel cookware is now clean and ready for use. Repeat these steps whenever grease buildup becomes difficult to remove.
