How to Remove Calcium Buildup from a Shower Head
    1. How to Remove Calcium Buildup from a Shower Head, How to Remove Calcium Buildup from a Shower Head: step 1, image 1 of 2 How to Remove Calcium Buildup from a Shower Head, How to Remove Calcium Buildup from a Shower Head: step 1, image 2 of 2
      • Using an adjustable wrench, loosen the bolt that attaches the shower head to the wall spout by turning the wrench counterclockwise.
      • You may be able to loosen the shower head by hand.
      • Handle carefully because the shower head may be heavy.
      Ask FixBot
    2. How to Remove Calcium Buildup from a Shower Head: step 2, image 1 of 1
      • Use your hands to finish unscrewing the bolt.
      • Remove the shower head from the wall spout.
      Ask FixBot
    3. How to Remove Calcium Buildup from a Shower Head: step 3, image 1 of 3 How to Remove Calcium Buildup from a Shower Head: step 3, image 2 of 3 How to Remove Calcium Buildup from a Shower Head: step 3, image 3 of 3
      • Pour one cup of water into the plastic bag.
      • Completing this step over a sink may help to avoid spilling the water.
      Ask FixBot
    4. How to Remove Calcium Buildup from a Shower Head: step 4, image 1 of 3 How to Remove Calcium Buildup from a Shower Head: step 4, image 2 of 3 How to Remove Calcium Buildup from a Shower Head: step 4, image 3 of 3
      • Pour one cup of distilled vinegar into the plastic bag.
      • Completing this step over a sink may help to avoid spilling the solution.
      • If using the vinegar solution provided in steps 3 and 4 fails to provide adequate results, you may want to repeat the steps using CLR (Calcium, Lime, and Rust) solution instead.
      Ask FixBot
    5. How to Remove Calcium Buildup from a Shower Head: step 5, image 1 of 2 How to Remove Calcium Buildup from a Shower Head: step 5, image 2 of 2
      • Place the shower head face down into the plastic bag of vinegar solution.
      • Let the shower head sit for one hour before removing it from the plastic bag of vinegar solution.
      Ask FixBot
    6. How to Remove Calcium Buildup from a Shower Head: step 6, image 1 of 1
      • After one hour, remove the shower head from the plastic bag of vinegar solution.
      • Use a metal sponge to scrub in a circular motion to remove the treated calcium on the shower head.
      • Excessive scrubbing could damage the finish.
      Ask FixBot
    7. How to Remove Calcium Buildup from a Shower Head: step 7, image 1 of 2 How to Remove Calcium Buildup from a Shower Head: step 7, image 2 of 2
      • Place the shower head under running water to remove any extra calcium left behind.
      • If calcium is still present, repeat steps 5 through 7 as needed.
      Ask FixBot
    8. How to Remove Calcium Buildup from a Shower Head: step 8, image 1 of 2 How to Remove Calcium Buildup from a Shower Head: step 8, image 2 of 2
      • Clamp the adjustable wrench onto the bolt of the shower head.
      • Turn the adjustable wrench clockwise to tighten the shower head back onto the water spout.
      Ask FixBot
Finish Line
4 other people completed this guide.
Jacob Abrego
157 Reputation
1 Guide authored
Texas Tech, Team 26-6, Rauch Spring 2016 Member of Texas Tech, Team 26-6, Rauch Spring 2016
TTU-RAUCH-S16S26G6
3 Members
12 Guides authored
1 Guide Comment
How to remove rust stain (from iron) from bathroom tiles?
waihong yeung - Reply Share
Past 24 Hours: 3
Past 7 Days: 20
Past 30 Days: 99
All Time: 11,722
