How to Reinforce the Base of a Torn Backpack
  1. How to Reinforce the Base of a Torn Backpack, Backpack Base: step 1, image 1 of 1
    • Pull out any excess thread that is left over from the tear.
    • Make sure to be careful in pulling the thread to avoid causing excess damage.
    Ask FixBot
  2. How to Reinforce the Base of a Torn Backpack: step 2, image 1 of 1
    • Turn the backpack inside out.
    • Carefully do this to not make the hole bigger.
    Ask FixBot
  3. How to Reinforce the Base of a Torn Backpack: step 3, image 1 of 2 How to Reinforce the Base of a Torn Backpack: step 3, image 2 of 2
    • Pin the hole together using sewing pins.
    • Gently pin to avoid poking or hurting yourself with the pins.
    Ask FixBot
  4. How to Reinforce the Base of a Torn Backpack: step 4, image 1 of 2 How to Reinforce the Base of a Torn Backpack: step 4, image 2 of 2
    • Thread your needle with a similar color thread to your backpack.
    • Tie a knot at the end of the thread.
    Ask FixBot
  5. How to Reinforce the Base of a Torn Backpack: step 5, image 1 of 3 How to Reinforce the Base of a Torn Backpack: step 5, image 2 of 3 How to Reinforce the Base of a Torn Backpack: step 5, image 3 of 3
    • Sew the hole shut, removing pins as you go.
    • Use this Basic Sewing guide for exact stitching.
    • Unpin carefully to avoid poking or hurting yourself with the pins
    • Tie a knot at the end to close off the stitch.
    • Cut any excess thread.
    Ask FixBot
  6. How to Reinforce the Base of a Torn Backpack: step 6, image 1 of 3 How to Reinforce the Base of a Torn Backpack: step 6, image 2 of 3 How to Reinforce the Base of a Torn Backpack: step 6, image 3 of 3
    • Trace an additional piece of lining with ¼” seam allowance in the shape of the backpack bottom.
    • Cut the fabric for the lining.
    • Pin the fabric around the perimeter to the base of the backpack.
    Ask FixBot
  7. How to Reinforce the Base of a Torn Backpack: step 7, image 1 of 1
    • Sew the lining to the base of the inside out backpack using the same process in Step 5.
    • Use this Basic Sewing tutorial as needed.
    • Gently sew and unpin to avoid hurting yourself with the pins.
    Ask FixBot
  8. How to Reinforce the Base of a Torn Backpack: step 8, image 1 of 1
    • Enjoy your newly strengthened backpack!
    Ask FixBot
Congratulations you have now reinforced and repaired your backpack! Good as new if not better.
2 other people completed this guide.
Amber Irfan
181 Reputation
1 Guide authored
UC Davis, Team 4-4, Andersen Winter 2024 Member of UC Davis, Team 4-4, Andersen Winter 2024
UCD-ANDERSEN-W24S4G4
3 Members
2 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 16
Past 30 Days: 126
All Time: 1,748
