How to Reinforce a Hammock
    1. How to Reinforce a Hammock, How to Reinforce a Hammock: step 1, image 1 of 2 How to Reinforce a Hammock, How to Reinforce a Hammock: step 1, image 2 of 2
      • Remove and discard any damaged rope from your hammock.
      Ask FixBot
    2. How to Reinforce a Hammock: step 2, image 1 of 2 How to Reinforce a Hammock: step 2, image 2 of 2
      • Use a power drill and a 3/8 size drill bit to drill small hole in one side of the tree.
      Ask FixBot
    3. How to Reinforce a Hammock: step 3, image 1 of 1
      • Insert the screw eye screw into the hole and begin screwing it in to the tree until it is secured fully into the tree.
      • A screwdriver or flathead may be needed at this point to make sure the screw eye is all the way in the tree.
      Ask FixBot
    4. How to Reinforce a Hammock: step 4, image 1 of 2 How to Reinforce a Hammock: step 4, image 2 of 2
      • Attach the metal clasp to the rings attached to the end of the hammock.
      Ask FixBot
    5. How to Reinforce a Hammock: step 5, image 1 of 2 How to Reinforce a Hammock: step 5, image 2 of 2
      • Once your screw eye is inserted fully into the tree and your metal clasps are connected to the ends of the hammock you can attach the metal clasp to the the screw eye.
      Ask FixBot
    6. How to Reinforce a Hammock: step 6, image 1 of 1
      • After attaching the hammock to the tree, repeat steps 1-5 on the other side of the hammock to the other side.
      • You will want to make sure that the second tree is at least 6ft-7ft away from the first tree.
      Ask FixBot
Finish Line
Leanne Works
160 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 14
Past 30 Days: 61
All Time: 946
