How to Refinish Wood Furniture
  1. How to Refinish Wood Furniture, How to Refinish Wood Furniture: step 1, image 1 of 2 How to Refinish Wood Furniture, How to Refinish Wood Furniture: step 1, image 2 of 2
    • Remove all hardware from the furniture.
    Ask FixBot
  2. How to Refinish Wood Furniture: step 2, image 1 of 1
    • Next you will need to wash any grease or contaminations before sanding.
    • Washing your furniture prior to sanding will prevent dirt, grease, and contaminations from being sanded into the surface of the furniture.
    Ask FixBot
  3. How to Refinish Wood Furniture: step 3, image 1 of 1
    • After the surface is dry begin sanding.
    • Remember to only sand with the grain so the sanding scratches will blend in with the grain.
    Ask FixBot
  4. How to Refinish Wood Furniture: step 4, image 1 of 1
    • Spray or paint on your primer prior to painting.
    • Remember if using spray paint to apply in a sweeping motion.
    Ask FixBot
  5. How to Refinish Wood Furniture: step 5, image 1 of 1
    • After allowing primer to dry approximately 3 hours apply paint. Allow paint 24 hours to dry.
    • If you are able to see the primer mixed in the paint, you may need to apply second coat of paint if needed.
    Ask FixBot
Finish Line
2 other people completed this guide.
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 53
All Time: 396
