How to Reattach an Umbrella Strap
Views: 8.3K
View statistics:
Past 24 Hours:
3
Past 7 Days:
41
Past 30 Days:
255
All Time:
8,256
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 20 - 30 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
This guide walks you through steps to reattach a broken umbrella strap, which ultimately extends the life of your umbrella through repair and reduces waste.
For this guide, we’ll be detaching the broken umbrella strap with a seam ripper, then marking the original sewing lines with fabric chalk. We will then align and pin the umbrella fabric with sewing pins, sew along the marked lines, then tie off and trim any excess threads with scissors. This repair will also utilize a certain type of stitch, called a backstitch, which involves looping the thread back on itself to ensure strength and longevity. This stitch is also incredibly lucrative and can be used across many other types of sewing repairs.
With frequent rain, many individuals increase their usage of weather-protective gear like umbrellas. This increased usage can cause damage to the umbrella strap, preventing individuals from being able to neatly close the umbrella and ultimately, losing its full functionality.
Repairing this strap will help increase the lifespan of your umbrella, improving functionality and helping minimize potential waste. Production of umbrellas involves a mix of materials that take a long time to break down in landfills like synthetic fabrics, metal, and plastic. By choosing to repair your umbrella instead of throwing it out, you're preventing waste and mitigating overconsumption.
    1. How to Reattach an Umbrella Strap, How to Reattach an Umbrella Strap: step 1, image 1 of 3 How to Reattach an Umbrella Strap, How to Reattach an Umbrella Strap: step 1, image 2 of 3 How to Reattach an Umbrella Strap, How to Reattach an Umbrella Strap: step 1, image 3 of 3
      • CAUTION: Seam rippers have a sharp blade; always use with caution and be aware of surroundings.
      • Notice how the strap is attached to the rest of the umbrella. The orientation matters.
      • Expose the broken stitching holding the umbrella and strap together.
      • Detach the two pieces by using the seam ripper to pull out the threads and rip through them.
      Ask FixBot
    2. How to Reattach an Umbrella Strap: step 2, image 1 of 1
      • Remove any excess thread left on the umbrella strap.
      Ask FixBot
    3. How to Reattach an Umbrella Strap: step 3, image 1 of 2 How to Reattach an Umbrella Strap: step 3, image 2 of 2
      • Lay the umbrella strap flat, then mark the original sewing line with a piece of fabric chalk.
      Ask FixBot
    4. How to Reattach an Umbrella Strap: step 4, image 1 of 2 How to Reattach an Umbrella Strap: step 4, image 2 of 2
      • Repeat Step 3 for the body of the umbrella.
      Ask FixBot
    5. How to Reattach an Umbrella Strap: step 5, image 1 of 3 How to Reattach an Umbrella Strap: step 5, image 2 of 3 How to Reattach an Umbrella Strap: step 5, image 3 of 3
      • CAUTION: Pins have a sharp point. Use with caution!
      • Align both pieces of the fabric together in the original orientation using the marked white lines as guidance.
      • Take one pin and push it down through both layers of the fabric above the original stitching line.
      • When the pin is halfway through the fabric, push it back up through the two layers.
      • Repeat this process for the second pin below the original stitching line.
      Ask FixBot
    6. How to Reattach an Umbrella Strap: step 6, image 1 of 2 How to Reattach an Umbrella Strap: step 6, image 2 of 2
      • Cut 12 inches of black thread with a pair of scissors.
      Ask FixBot
    7. How to Reattach an Umbrella Strap: step 7, image 1 of 3 How to Reattach an Umbrella Strap: step 7, image 2 of 3 How to Reattach an Umbrella Strap: step 7, image 3 of 3
      • Hold the needle with the eye facing upwards, then carefully push the black thread into the needle's eye.
      • Tip: Moisten end of the thread to ease threading process and prevent fraying.
      • Taking the other end of the thread that did not go through the eye of the needle, make a small loop, and run that end of the thread through it.
      • Pull the thread to tighten and secure the knot.
      Ask FixBot
    8. How to Reattach an Umbrella Strap: step 8, image 1 of 2 How to Reattach an Umbrella Strap: step 8, image 2 of 2
      • KEY TIP: The holes of the previous stitching should still be visible. Follow these holes for the new stitches. If they are not visible, individual stitches are around an 1/8 inch in length each.
      • Begin the stitch at the second hole in from the right.
      • Poke the needle up through the fabric from the underside.
      • Pull the needle through until the knot hits the fabric; you will feel resistance.
      Ask FixBot
    9. How to Reattach an Umbrella Strap: step 9, image 1 of 3 How to Reattach an Umbrella Strap: step 9, image 2 of 3 How to Reattach an Umbrella Strap: step 9, image 3 of 3
      • Poke the needle down through the first hole (which is to the right of the second hole).
      • While the needle is halfway through the first hole, angle it up, then poke it through the third hole.
      • Flip the fabric over to check that the needle is piercing the fabric, as shown in the third photo.
      Ask FixBot
    10. How to Reattach an Umbrella Strap: step 10, image 1 of 2 How to Reattach an Umbrella Strap: step 10, image 2 of 2
      • Pull the needle and thread through the fabric completely until the thread is tight against the fabric.
      • Make sure the fabric is not scrunched.
      Ask FixBot
    11. How to Reattach an Umbrella Strap: step 11, image 1 of 2 How to Reattach an Umbrella Strap: step 11, image 2 of 2
      • Repeat the same methods in Steps 9 and 10 until you have pulled the needle up through the last hole.
      • Remove the pins.
      Ask FixBot
    12. How to Reattach an Umbrella Strap: step 12, image 1 of 3 How to Reattach an Umbrella Strap: step 12, image 2 of 3 How to Reattach an Umbrella Strap: step 12, image 3 of 3
      • To complete the line of stitches, poke the needle through the hole to the right.
      • Pull the needle straight down instead of bringing it back up through the fabric.
      • Pull the thread until it is tight.
      Ask FixBot
    13. How to Reattach an Umbrella Strap: step 13, image 1 of 3 How to Reattach an Umbrella Strap: step 13, image 2 of 3 How to Reattach an Umbrella Strap: step 13, image 3 of 3
      • Flip the fabric over to see the underside.
      • Create a loop with the thread.
      • Run the needle through the open loop.
      • Pull the thread tight to create a knot.
      Ask FixBot
    14. How to Reattach an Umbrella Strap: step 14, image 1 of 1
      • Trim off any excess thread on the fixed umbrella strap and the body.
      Ask FixBot
    15. How to Reattach an Umbrella Strap: step 15, image 1 of 1
      • Pull both ends of the umbrella fabric to test the strength of stitching. The repair is now complete!
      Ask FixBot
Now your umbrella is ready to be used!
Emily-Mae McConihe
241 Reputation
1 Guide authored
UC Davis, Team 2-9, Andersen Winter 2025 Member of UC Davis, Team 2-9, Andersen Winter 2025
UCD-ANDERSEN-W25S2G9
2 Members
12 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 41
Past 30 Days: 255
All Time: 8,256
