How to Reattach a Cover to a Hardcover Book
  1. How to Reattach a Cover to a Hardcover Book, How to Reattach a Cover to a Hardcover Book: step 1, image 1 of 2 How to Reattach a Cover to a Hardcover Book, How to Reattach a Cover to a Hardcover Book: step 1, image 2 of 2
    • Open the book to expose the detached cover.
    Ask FixBot
  2. How to Reattach a Cover to a Hardcover Book: step 2, image 1 of 3 How to Reattach a Cover to a Hardcover Book: step 2, image 2 of 3 How to Reattach a Cover to a Hardcover Book: step 2, image 3 of 3
    • Cut a strip of wax paper a little longer than the length of the spine (about half an inch) with your scissors.
    • Set the wax paper into the hollow of the spine.
    • The wax paper should lay flat in the hollow to protect the inner cover of your book.
    Ask FixBot
  3. How to Reattach a Cover to a Hardcover Book: step 3, image 1 of 2 How to Reattach a Cover to a Hardcover Book: step 3, image 2 of 2
    • Cut a length of book repair tape a little longer than the length of the spine (about half an inch) with your scissors.
    • The book repair tape needs to be about twice the width of the spine of the book. If your book repair tape meets this requirement, skip to Step 9. If your book repair tape is not wide enough, continue with Steps 4 - 8.
    Ask FixBot
  4. How to Reattach a Cover to a Hardcover Book: step 4, image 1 of 3 How to Reattach a Cover to a Hardcover Book: step 4, image 2 of 3 How to Reattach a Cover to a Hardcover Book: step 4, image 3 of 3
    • Cut two more lengths of book repair tape the same length as the first (about half an inch longer than the spine of your book).
    • Fold one piece of book repair tape lengthwise (hot dog style). The gummed side of the tape should be on the outside of the fold.
    • Book repair tape has two sides. One is gummed (covered in glue), and one is not. The gummed side will be slightly yellow and darker than the non-gummed side.
    Ask FixBot
  5. How to Reattach a Cover to a Hardcover Book: step 5, image 1 of 1
    • Set the folded piece of book repair tape flat onto the table.
    • Wet your paint brush with water.
    • Gently moisten one gummed side of the folded book repair tape with your paintbrush. This activates the glue.
    • Be careful not to oversaturate the tape. There should be no excess water, but all areas of the tape should be moist.
    Ask FixBot
  6. How to Reattach a Cover to a Hardcover Book: step 6, image 1 of 2 How to Reattach a Cover to a Hardcover Book: step 6, image 2 of 2
    • Lift the folded book repair tape up by the edges using your fingers.
    • Press the moistened side of the tape down on the bottom half of the non-gummed side of your second piece of book repair tape.
    • Press and smooth the two pieces together using the bone folder.
    • Allow two to three minutes to dry.
    Ask FixBot
  7. How to Reattach a Cover to a Hardcover Book: step 7, image 1 of 2 How to Reattach a Cover to a Hardcover Book: step 7, image 2 of 2
    • Wet your paintbrush with water.
    • Gently moisten the remaining gummed side of the folded book repair tape with your paintbrush.
    • Again, be careful not to oversaturate the tape.
    Ask FixBot
  8. How to Reattach a Cover to a Hardcover Book: step 8, image 1 of 2 How to Reattach a Cover to a Hardcover Book: step 8, image 2 of 2
    • Pick up the third (and final) piece of book repair tape.
    • Press the bottom half of the non-gummed side to the moistened piece of folded book repair tape.
    • We have used the folded piece of book repair tape to create a hinge, effectively doubling the width of the book repair tape for our repair.
    Ask FixBot
  9. How to Reattach a Cover to a Hardcover Book: step 9, image 1 of 3 How to Reattach a Cover to a Hardcover Book: step 9, image 2 of 3 How to Reattach a Cover to a Hardcover Book: step 9, image 3 of 3
    • Fold your piece of book repair tape lengthwise (hot dog style). The gummed side of the tape should be on the outside of the fold.
    • Press down firmly on the fold to create a tight crease.
    Ask FixBot
  10. How to Reattach a Cover to a Hardcover Book: step 10, image 1 of 1
    • If needed, trim the folded book repair tape to size.
    • When folded, the piece of book repair tape should be the same width as the spine of your book.
    Ask FixBot
  11. How to Reattach a Cover to a Hardcover Book: step 11, image 1 of 2 How to Reattach a Cover to a Hardcover Book: step 11, image 2 of 2
    • Place the folded book repair tape flat onto the table.
    • Gently moisten one gummed side of the folded book repair tape with your paintbrush to activate the glue.
    Ask FixBot
  12. How to Reattach a Cover to a Hardcover Book: step 12, image 1 of 3 How to Reattach a Cover to a Hardcover Book: step 12, image 2 of 3 How to Reattach a Cover to a Hardcover Book: step 12, image 3 of 3
    • Lift up the book repair tape with the folded edge up.
    • Press the moistened side to the spine of the book (the pages).
    • Press the tape down firmly against the spine with your fingers.
    Ask FixBot
  13. How to Reattach a Cover to a Hardcover Book: step 13, image 1 of 2 How to Reattach a Cover to a Hardcover Book: step 13, image 2 of 2
    • Use the bone folder to press and smooth the book repair tape to the spine so the glue adheres evenly.
    Ask FixBot
  14. How to Reattach a Cover to a Hardcover Book: step 14, image 1 of 1
    • Close the book.
    Ask FixBot
  15. How to Reattach a Cover to a Hardcover Book: step 15, image 1 of 2 How to Reattach a Cover to a Hardcover Book: step 15, image 2 of 2
    • Reopen the book.
    • Remove the wax strip from the hollow of the spine.
    • Trim the excess book repair tape with your scissors.
    • Trim as close to the spine of your book as you can.
    Ask FixBot
  16. How to Reattach a Cover to a Hardcover Book: step 16, image 1 of 3 How to Reattach a Cover to a Hardcover Book: step 16, image 2 of 3 How to Reattach a Cover to a Hardcover Book: step 16, image 3 of 3
    • Cut a large piece of wax paper to sufficiently cover the pages of your book.
    • Place the wax paper over the pages of your book to protect it.
    Ask FixBot
  17. How to Reattach a Cover to a Hardcover Book: step 17, image 1 of 2 How to Reattach a Cover to a Hardcover Book: step 17, image 2 of 2
    • Lift the book repair tape away from the spine of the book.
    • Gently moisten the exposed gummed side of the tape evenly.
    • Again, be careful not to oversaturate the tape with water.
    Ask FixBot
  18. How to Reattach a Cover to a Hardcover Book: step 18, image 1 of 3 How to Reattach a Cover to a Hardcover Book: step 18, image 2 of 3 How to Reattach a Cover to a Hardcover Book: step 18, image 3 of 3
    • Hold the book repair tape down with one hand.
    • Press the other edge of the book repair tape down towards the spine with the bone folder.
    • Push the detached cover towards the spine to attach it to the book repair tape.
    Ask FixBot
  19. How to Reattach a Cover to a Hardcover Book: step 19, image 1 of 2 How to Reattach a Cover to a Hardcover Book: step 19, image 2 of 2
    • Close the book.
    • Keep a firm hand pressing down on the spine.
    Ask FixBot
  20. How to Reattach a Cover to a Hardcover Book: step 20, image 1 of 3 How to Reattach a Cover to a Hardcover Book: step 20, image 2 of 3 How to Reattach a Cover to a Hardcover Book: step 20, image 3 of 3
    • Run the bone folder firmly along the spine and crease of the book so that the glue adheres evenly.
    Ask FixBot
  21. How to Reattach a Cover to a Hardcover Book: step 21, image 1 of 3 How to Reattach a Cover to a Hardcover Book: step 21, image 2 of 3 How to Reattach a Cover to a Hardcover Book: step 21, image 3 of 3
    • Hold the book firmly shut.
    • Wrap a rubber band around the top, middle, and bottom of your book to secure it.
    • Let the book settle with the rubber bands for 24 hours.
    • Remove the wax paper after the book has settled for at least 24 hours.
    Ask FixBot
  22. How to Reattach a Cover to a Hardcover Book: step 22, image 1 of 1
    • If you are unhappy with the look of your repair, we can use document repair tape to mask it. Steps 23 - 25 outline this process, but are completely optional.
    Ask FixBot
  23. How to Reattach a Cover to a Hardcover Book: step 23, image 1 of 1
    • Cut a length of document repair tape to adequately cover the repair (about the same length as the spine of your book).
    Ask FixBot
  24. How to Reattach a Cover to a Hardcover Book: step 24, image 1 of 3 How to Reattach a Cover to a Hardcover Book: step 24, image 2 of 3 How to Reattach a Cover to a Hardcover Book: step 24, image 3 of 3
    • Remove the adhesive back of the document repair tape.
    • Align the tape along the crease of the spine with the exposed repair.
    • Smooth the tape down carefully with your fingers.
    • If desired, repeat this process with another piece of document repair tape.
    • When aligning the document repair tape, about half of the tape should adhere to the cover and the other to the page beside it.
    Ask FixBot
  25. How to Reattach a Cover to a Hardcover Book: step 25, image 1 of 1
    • The repair is now masked with the document repair tape.
    Ask FixBot
2 other people completed this guide.
0 Guide Comments
Past 24 Hours: 7
Past 7 Days: 46
Past 30 Days: 230
All Time: 11,526
