How to Realign a Sliding Closet Door
    1. How to Realign a Sliding Closet Door, How to Realign a Sliding Closet Door: step 1, image 1 of 3 How to Realign a Sliding Closet Door, How to Realign a Sliding Closet Door: step 1, image 2 of 3 How to Realign a Sliding Closet Door, How to Realign a Sliding Closet Door: step 1, image 3 of 3
      • Investigate the cleanliness of the tracks.
      • If the tracks are dirty, scrub them with toothbrush to clean out the dust.
      • You can use a rag or a hand vacuum to remove the loosened dust.
      Ask FixBot
    2. How to Realign a Sliding Closet Door: step 2, image 1 of 2 How to Realign a Sliding Closet Door: step 2, image 2 of 2
      • Investigate whether the sliding door is along the top tracks.
      • If the door is completely unhooked from the top tracks:
      • Try to lift up on the door.
      • Slightly push the door in toward the closet.
      • Hook in the top rollers back onto the upper tracks.
      Ask FixBot
    3. How to Realign a Sliding Closet Door: step 3, image 1 of 1
      • If the bottom rollers do not align, follow these steps:
      • CAUTION: The doors may be heavy. Ask somebody for assistance.
      • Do not force anything.
      • Gently try to lift up on the door and guide its bottom rollers into the bottom tracks.
      • If the door still needs to be realigned, continue to Step 4.
      • If the door is successfully realigned with the bottom tracks, continue to Step 6.
      Ask FixBot
    4. How to Realign a Sliding Closet Door: step 4, image 1 of 3 How to Realign a Sliding Closet Door: step 4, image 2 of 3 How to Realign a Sliding Closet Door: step 4, image 3 of 3
      • Lift the top rollers up, then above and onto the top tracks.
      • This is what gives the door enough space to fit back into the bottom tracks.
      • If this doesn't work, see Step 5.
      Ask FixBot
    5. How to Realign a Sliding Closet Door: step 5, image 1 of 3 How to Realign a Sliding Closet Door: step 5, image 2 of 3 How to Realign a Sliding Closet Door: step 5, image 3 of 3
      • Another sliding door behind may be creating a space constraint.
      • Grab the sliding door that is behind it.
      • Lift it up so that the rollers at the bottom disconnect with the track.
      • Keep the top rollers connected.
      • Put down the door so that the bottom rollers are behind the track, closer to the closet.
      Ask FixBot
    6. How to Realign a Sliding Closet Door: step 6, image 1 of 3 How to Realign a Sliding Closet Door: step 6, image 2 of 3 How to Realign a Sliding Closet Door: step 6, image 3 of 3
      • Grab the door in front.
      • Attach it to both the top and bottom tracks.
      • Grab the door behind and do the same.
      Ask FixBot
    7. How to Realign a Sliding Closet Door: step 7, image 1 of 3 How to Realign a Sliding Closet Door: step 7, image 2 of 3 How to Realign a Sliding Closet Door: step 7, image 3 of 3
      • The doors should be located properly on their tracks.
      • Try to slide the doors along the tracks.
      • If they don't slide well, you may need to lubricate the tracks:
      • Grab a lubricant: olive oil, fish oil, mineral oil, or petroleum jelly.
      • Apply a small amount of the lubricant to the edge of the rag.
      • Fit the edge of the rag into the tracks.
      • Spread the rag throughout the tracks to spread the lubricant.
      • Slide the closet door along the tracks to spread the lubricant further.
      Ask FixBot
Thank you for considering this guide. To maintain properly working sliding closet doors, periodically clean and lubricate the tracks as described in this guide.
16 other people completed this guide.
Annamarie Roger
548 Reputation
1 Guide authored
Cal Poly, Team 28-5, Green Spring 2015 Member of Cal Poly, Team 28-5, Green Spring 2015
CPSU-GREEN-S15S28G5
3 Members
36 Guides authored
3 Guide Comments
Bonjour :)
Je suis très contente de vos explications accompagnées de photos !
Elles vont m'être très utiles pour, enfin, remettre en état mon placard coulissant ;)
Merci beaucoup ! Vous êtes géniale !
Claire.
Defontaine - Reply Share
Hi, so this was sorta useful for me but I still have another question. My door slides along the floor and doesn't have a bottom track. Any tips as to how I'd go about fixing it? Thanks
Flying Dolphin 101 - Reply Share
Very helpful, helped me fixed a cabinet door. Thanks a lot !
Mem's - Reply Share
Past 24 Hours: 16
Past 7 Days: 152
Past 30 Days: 804
All Time: 296,556
