How to Realign a Bike Stand
View statistics:
Past 24 Hours:
5
Past 7 Days:
33
Past 30 Days:
142
All Time:
709
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
Welcome to our comprehensive guide on adjusting the bike stand for the URBAN COMMUTER BIKE (Model No. 671060). This guide will help you achieve optimal functionality for your bike stand, whether you are an experienced cyclist or new to bike maintenance. By following this step-by-step tutorial, you will learn how to remove, adjust, and reattach your bike stand with ease. Each step is accompanied by clear instructions and detailed photos to ensure a smooth process.
Before you begin, please note the following tips and warnings:
  • Ensure your bike is securely supported to prevent any accidents while adjusting the stand.
  • Be cautious of any sharp edges or moving parts that could cause injury.
  • If your bike has any electrical components, make sure to disconnect the battery to avoid any electrical hazards.
Let’s dive in and get your bike stand perfectly positioned for your riding pleasure!
Video Overview
    1. How to Realign a Bike Stand, Bike Stand: step 1, image 1 of 2 How to Realign a Bike Stand, Bike Stand: step 1, image 2 of 2
      • Remove the bike stand by loosening the bolts connecting it to the frame.
      • Use a wrench to turn the bolts counterclockwise.
      Ask FixBot
    2. How to Realign a Bike Stand: step 2, image 1 of 2 How to Realign a Bike Stand: step 2, image 2 of 2
      • Now that the bolt is loose you should be able to move the bike stand around.
      • Identify the optimal position for reattaching the stand to avoid interference with pedaling.
      Ask FixBot
    3. How to Realign a Bike Stand: step 3, image 1 of 3 How to Realign a Bike Stand: step 3, image 2 of 3 How to Realign a Bike Stand: step 3, image 3 of 3
      • Use sandpaper to adjust the shape of the stand or frame if necessary.
      Ask FixBot
    4. How to Realign a Bike Stand: step 4, image 1 of 2 How to Realign a Bike Stand: step 4, image 2 of 2
      • Reattach the stand securely to the frame using the same bolts and ensure it is aligned properly.
      Ask FixBot
      • Test the bike to ensure the stand no longer obstructs pedaling.
      Ask FixBot
Finish Line
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 33
Past 30 Days: 142
All Time: 709
