How to Propagate a Plant in Water
Views: 3.6K
View statistics:
Past 24 Hours:
11
Past 7 Days:
58
Past 30 Days:
339
All Time:
3,583
Comments: 0
Go to guide comments
Completed: 5
5 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 minutes
Difficulty: Very easy
Introduction
Go to step 1 ↓
House plants are extremely popular. Whether they are big or small, they liven up a room significantly. However, without the proper care, plants like Schefflera arboricola (also known as umbrella plants) can wilt and die.
By propagating your plant in water, you can save and support a plant's growth which keeps it happy and healthy! Propagating plants can also be used to multiply plants, share with others, or revive a dying plant. You don't need any expensive gardening tools or a green thumb to keep your plants from dying. Follow this guide on how to preserve your plants longer and keep them alive!
Tools
    1. How to Propagate a Plant in Water, How to Propagate a Plant in Water: step 1, image 1 of 2 How to Propagate a Plant in Water, How to Propagate a Plant in Water: step 1, image 2 of 2
      • Using scissors or shears cut the plant below a node.
      • Node: a point where a leaf or branch emerges.
      Ask FixBot
    2. How to Propagate a Plant in Water: step 2, image 1 of 2 How to Propagate a Plant in Water: step 2, image 2 of 2
      • Remove the bottom leaves and cut the plant diagonally.
      • Cutting the plant in a diagonal will increase surface area and allow for better water consumption.
      Ask FixBot
    3. How to Propagate a Plant in Water: step 3, image 1 of 2 How to Propagate a Plant in Water: step 3, image 2 of 2
      • Optional: Coat the cutting in rooting powder.
      • Rooting powder will accelerate the rooting process and yield a higher success rate.
      Ask FixBot
    4. How to Propagate a Plant in Water: step 4, image 1 of 1
      • Fill a glass cup with water.
      Ask FixBot
    5. How to Propagate a Plant in Water: step 5, image 1 of 1
      • Place the cutting in the cup.
      • The cup should be in a well-ventilated area with bright indirect light.
      • Change the water every week to prevent bacterial growth.
      Ask FixBot
    6. How to Propagate a Plant in Water: step 6, image 1 of 2 How to Propagate a Plant in Water: step 6, image 2 of 2
      • Once the roots are 1-2 inches long, transfer to medium (soil, lecca, etc.).
      • Water regularly to reduce shock.
      Ask FixBot
You did it! Congratulations on successfully propagating your plant in water!
5 other people completed this guide.
Daniela Perez
235 Reputation
1 Guide authored
CSU Sacramento, Team 1-14, Laflen Spring 2024 Member of CSU Sacramento, Team 1-14, Laflen Spring 2024
CSUSAC-LAFLEN-S24S1G14
2 Members
12 Guides authored
0 Guide Comments
Past 24 Hours: 11
Past 7 Days: 58
Past 30 Days: 339
All Time: 3,583
