Shop the Holiday Gift Guide
How to Paint Oak Cabinets
View statistics:
Past 24 Hours:
6
Past 7 Days:
19
Past 30 Days:
65
All Time:
926
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Community-Contributed Guide
Tools
      • Remove doors and label (write behind the hinges). Use 3M Advanced Masking plastic.
      • Mask the openings in the cabinet frames
      Ask FixBot
      • Scrub the doors with Dawn dish soap to clean (you can also use a trisodium phosphate - TSP). Use gloves and eye protection. Spray on the tsp and let it sit for a few minutes, then wipe it off with a clean towel. Use a five in one tool to get the hard-to-reach corners.
      • Caulk the panel inside corners. Use lightning caulk. Then bondo and prime Nick's and dings.
      • Sand the bondo and and the rest of the cabinets. Use denatured alcohol and steel wool to prep surfaces you can't sand. Then use a vacuum, air blower, and tack cloth to clean.
      Ask FixBot
      • Apply first coat of catalyzed laquer primer surfacer with sprayer. Use risers (plywood and nails) to raise the painted material off of your table and minimize smudges.
      • Then use aqua coat grain filler.
      • Spray on the second coat of primer (spray opposite direction) or you can use a roller. Prime the hard to see surfaces of the frame first, then focus on the face frame fronts where quality issues might be more visible so you can correct them.
      • Then put grain filler on with plastic scraper. Use a cloth to wipe excess and apply in hard to reach areas.
      Ask FixBot
      • Sand with 220 grit sandpaper.
      • Apply first top coat and let dry.
      • Apply second top coat and let dry.
      • Inspect for blemishes in sand down if needed, then touch up.
      • Reassemble cabinets.
      Ask FixBot
      • Prep. Use a 7/64 drill bit for pilots holes on hidden side of doors, then install cup hooks and hang on hangers that rotate.
      • Use 3M 20/20 tape or Frog Tape for prep.
      Ask FixBot
Author
with
Austyn Smith
193 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 19
Past 30 Days: 65
All Time: 926
