How to Open the Xiaomi Mi Watch 2021
  1. How to Open the Xiaomi Mi Watch 2021, Unfasten the screws: step 1, image 1 of 1
    • Opening the Mi Watch will compromise its waterproof seals. Have replacement seals ready before you proceed past this step, or take care to avoid liquid exposure if you reassemble your watch without replacing the seals.
    • Before starting the disassembly, turn off your watch.
    • Remove the four 3.2 mm-long T3 Torx screws on the back of the watch.
    • A T3 screwdriver has a tight fit on these screws and might require a bit more downward pressure to unfasten the screws. A T2 fits as well but poses the risk to strip the screw heads.
    Ask FixBot
  2. How to Open the Xiaomi Mi Watch 2021, Create a small gap: step 2, image 1 of 3 How to Open the Xiaomi Mi Watch 2021, Create a small gap: step 2, image 2 of 3 How to Open the Xiaomi Mi Watch 2021, Create a small gap: step 2, image 3 of 3
    • Insert the flat end of a spudger into the loudspeaker opening at the top edge of the rear case assembly.
    • Push the spudger upwards to create a small gap between the rear case assembly and the watch housing.
    Ask FixBot
  3. How to Open the Xiaomi Mi Watch 2021, Pry up the rear case: step 3, image 1 of 2 How to Open the Xiaomi Mi Watch 2021, Pry up the rear case: step 3, image 2 of 2
    • Insert your spudger into the gap and pry up the rear case assembly.
    • Only work with the edge of your spudger and do not insert it deeper than 3 mm.
    • Steady the rear case assembly with a finger to prevent it from suddenly popping open and damaging the flex cable.
    • Don’t try to remove the rear case assembly all the way yet. It is still connected to the motherboard with a thin flex cable.
    Ask FixBot
  4. How to Open the Xiaomi Mi Watch 2021, Open the watch assembly: step 4, image 1 of 2 How to Open the Xiaomi Mi Watch 2021, Open the watch assembly: step 4, image 2 of 2
    • Carefully swing open the rear case assembly by folding the rear case to the side with the watch buttons.
    • Avoid straining the flex cable during this procedure.
    Ask FixBot
3 other people completed this guide.
Dominik Schnabelrauch
260,489 Reputation
682 Guides authored
iFixit Member of iFixit
Staff
122 Members
26,665 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 23
Past 30 Days: 109
All Time: 4,051
