How to Open the Razer Kishi
  1. How to Open the Razer Kishi, Remove the screws: step 1, image 1 of 1
    • The opening process is the same on both sides. For simplicity, this guide shows only the right-side opening process. Unscrew whichever side you wish to open and work on.
    • For the right side, remove the five Y0 screws securing the right side of the controller.
    • Four 9.2 mm screws
    • One 7.2 mm screw
    • If you wish to open the left side, remove the five Y0 screws securing the left side of the controller.
    • One 7.2 mm screw
    Ask FixBot
  2. How to Open the Razer Kishi, Release the bottom edge clips: step 2, image 1 of 3 How to Open the Razer Kishi, Release the bottom edge clips: step 2, image 2 of 3 How to Open the Razer Kishi, Release the bottom edge clips: step 2, image 3 of 3
    • Both cases are held together by plastic clips.
    • Insert an opening pick in the seam between the top and bottom case, at the bottom left corner of the controller.
    • With the pick still in the seam, slide it along the bottom edge to the bottom right corner to loosen the plastic clips.
    Ask FixBot
  3. How to Open the Razer Kishi, Release the side edge clips: step 3, image 1 of 2 How to Open the Razer Kishi, Release the side edge clips: step 3, image 2 of 2
    • Slide the opening pick along the right edge to loosen the plastic clips.
    Ask FixBot
  4. How to Open the Razer Kishi, Release the top edge clips: step 4, image 1 of 2 How to Open the Razer Kishi, Release the top edge clips: step 4, image 2 of 2
    • Slide the opening pick along the top edge to loosen the remaining plastic clips.
    • Don't try to remove the top side yet, the case is still connected to the board.
    Ask FixBot
  5. How to Open the Razer Kishi: step 5, image 1 of 3 How to Open the Razer Kishi: step 5, image 2 of 3 How to Open the Razer Kishi: step 5, image 3 of 3
    • Carefully lift the top side and unfold it to the right, like a book.
    Ask FixBot
  6. How to Open the Razer Kishi, Disconnect the interconnect cable: step 6, image 1 of 3 How to Open the Razer Kishi, Disconnect the interconnect cable: step 6, image 2 of 3 How to Open the Razer Kishi, Disconnect the interconnect cable: step 6, image 3 of 3
    • Using the pointed end of a spudger, push the grey tabs on the interconnect socket away from the socket, parallel to the interconnect cable, to release the cable.
    • Pull the cable out of the socket.
    Ask FixBot
Opening didn’t go as planned? Try some basic troubleshooting, or ask our Answers community for help.
5 other people completed this guide.
Adriana Zwink
67,717 Reputation
167 Guides authored
iFixit Member of iFixit
Staff
123 Members
30,155 Guides authored
1 Guide Comment
Is the left side glued? Because I can't separate the left side, as it is sealed shut like it was glued together.
Punkie Spam - Reply Share
Past 24 Hours: 2
Past 7 Days: 16
Past 30 Days: 86
All Time: 9,619
