Up to 20% off select tools
How to Open the Logitech G903
Views: 38K
View statistics:
Past 24 Hours:
15
Past 7 Days:
109
Past 30 Days:
432
All Time:
37,864
Comments: 5
3 comments on steps, 2 guide comments.
Go to guide comments
Completed: 20
20 people have marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 - 30 minutes
Difficulty: Moderate
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Tools
Introduction
Go to step 1 ↓
Follow this guide to open your Logitech G903 wireless mouse.
Opening your mouse gives you access to clean its internals, troubleshoot mechanical problems, or replace a part.
    1. How to Open the Logitech G903, Turn off the mouse: step 1, image 1 of 2 How to Open the Logitech G903, Turn off the mouse: step 1, image 2 of 2
      • Before you begin, flip the mouse's power switch to the OFF position.
      • A red indicator should be visible beneath the switch.
      • Unplug all cables from the mouse.
      • Throughout the repair, it may be helpful to lay the mouse on a soft cloth to stabilize it and prevent damage while you work.
      Ask FixBot
    1. How to Open the Logitech G903, Heat the mouse foot: step 2, image 1 of 1
      • The feet are secured to the bottom of the mouse with strong adhesive. In order to cleanly remove them, the adhesive needs to be thoroughly heated.
      • Heat an iOpener and lay it on the mouse feet for one minute to heat the adhesive.
      • Alternatively, you can use a hair dryer on the Low heat setting to soften the adhesive.
      • If you're using a hair dryer, only heat the feet a few seconds at a time or you may warp the plastic shell.
      Ask FixBot
    2. How to Open the Logitech G903, Separate the mouse foot adhesive: step 3, image 1 of 3 How to Open the Logitech G903, Separate the mouse foot adhesive: step 3, image 2 of 3 How to Open the Logitech G903, Separate the mouse foot adhesive: step 3, image 3 of 3
      • The feet have two layers—a rubberized one and an adhesive pad underneath.
      • If you're reusing the feet, be very careful not to separate the two layers or damage the feet.
      • Slide the tip of an opening pick under an edge of the bottom mouse foot, making sure it goes under both the foot and its adhesive pad.
      • If the foot feels stuck, apply more heat and try again.
      • Gently slide the pick farther under the foot and lift until you can grip it with your fingers.
      • Use your fingers to peel up and remove the foot.
      Ask FixBot
    3. How to Open the Logitech G903, Clean off the old adhesive: step 4, image 1 of 3 How to Open the Logitech G903, Clean off the old adhesive: step 4, image 2 of 3 How to Open the Logitech G903, Clean off the old adhesive: step 4, image 3 of 3
      • If the rubber layer separated from its adhesive pad:
      • Slide the flat end of a spudger under an edge of the adhesive. If the adhesive seems stuck, you may need to heat it further.
      • Peel the adhesive off.
      • To install a new foot:
      • If any of the feet got damaged during removal or separated from their adhesive pads, replace them.
      • Use a spudger to carefully scrape up and remove any remaining adhesive bits.
      • Use isopropyl alcohol and a microfiber cloth to thoroughly clean all adhesive residue from the foot recesses. Allow the surface to completely dry (about 1–2 minutes).
      • Remove the feet from their backing and firmly press them into place.
      Ask FixBot
    1. How to Open the Logitech G903, Remove the pentagonal mouse feet: step 5, image 1 of 2 How to Open the Logitech G903, Remove the pentagonal mouse feet: step 5, image 2 of 2
      • Repeat the process to remove the two pentagonal mouse feet on the left and right sides.
      Ask FixBot
    2. How to Open the Logitech G903, Heat the Logitech sticker: step 6, image 1 of 1
      • The Logitech sticker on the bottom of the mouse is sensitive to heat and crumbles easily. If you want to keep that sticker intact, apply as little heat as possible and remove the sticker carefully.
      • If you don't want to remove the sticker all the way, you can puncture it with a screwdriver where the two screws are located beneath it.
      • Heat an iOpener and apply it to the Logitech sticker for one minute to soften its adhesive.
      • If you're using a hair dryer, only heat the sticker a few seconds at a time or you may warp the plastic shell.
      Ask FixBot
    3. How to Open the Logitech G903, Remove the Logitech sticker: step 7, image 1 of 3 How to Open the Logitech G903, Remove the Logitech sticker: step 7, image 2 of 3 How to Open the Logitech G903, Remove the Logitech sticker: step 7, image 3 of 3
      • If you want to reuse the sticker, be delicate and work slowly.
      • Slide the tip of an opening pick under an edge of the Logitech sticker.
      • Gently slide the pick farther under the sticker and lift until you can grip it with your fingers.
      • If the sticker feels stuck, apply more heat and try again.
      • Use your fingers to peel up and remove the sticker.
      Ask FixBot
    4. How to Open the Logitech G903, Remove the case screws: step 8, image 1 of 2 How to Open the Logitech G903, Remove the case screws: step 8, image 2 of 2
      • Use a Phillips screwdriver to remove the seven 4.5 mm‑long screws securing the two halves of the mouse together.
      • On older models, the top middle screw may be a Torx T5.
      Ask FixBot
    5. How to Open the Logitech G903, Open the mouse: step 9, image 1 of 3 How to Open the Logitech G903, Open the mouse: step 9, image 2 of 3 How to Open the Logitech G903, Open the mouse: step 9, image 3 of 3
      • Don't completely separate the two halves yet—they're still connected together by a delicate cable.
      • Swing the top case towards the rear of the mouse to access the internals.
      • Keep the top case lifted with one hand, or use something heavy to support it while you work.
      • Be careful not to strain the cable connecting the two halves.
      Ask FixBot
    6. How to Open the Logitech G903, Disconnect the interconnect cable: step 10, image 1 of 2 How to Open the Logitech G903, Disconnect the interconnect cable: step 10, image 2 of 2
      • Use a spudger or clean fingernail to gently flip the hinged locking flap on the interconnect cable ZIF connector up and towards the front of the mouse.
      Ask FixBot
    7. How to Open the Logitech G903: step 11, image 1 of 2 How to Open the Logitech G903: step 11, image 2 of 2
      • Use tweezers or your fingers to grip the interconnect cable by its pull tab and slide it out of the socket.
      Ask FixBot
    8. How to Open the Logitech G903, Disconnect the battery: step 12, image 1 of 3 How to Open the Logitech G903, Disconnect the battery: step 12, image 2 of 3 How to Open the Logitech G903, Disconnect the battery: step 12, image 3 of 3
      • Use a pair of tweezers to firmly grasp the sides of the battery connector.
      • Hold the tweezers with your fingers as close to the connector as possible to get a firm grip.
      • Pull the connector up and out of its socket, gently rocking it back and forth to loosen it.
      • During reassembly, make sure the connector is properly oriented—it should slide into place easily.
      Ask FixBot
    9. How to Open the Logitech G903, Remove the top half of the mouse: step 13, image 1 of 1
      • Remove the top half of the mouse.
      Ask FixBot
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
Reuse or Recycle—Never put discarded electronic parts in household waste. Visit Logitech Recycling to find your nearest recycling points, including the option to mail back old devices to Logitech for free if there’s no convenient solution in your area. You can also take your e-waste to any R2 or e-Stewards certified recycler. And don’t let good working parts or repaired devices die a slow death in your sock drawer—pass them along to someone who can use them.
Share your experience—Leave a comment here or send your feedback directly to Logitech at repair@logitech.com to help shape future repair guides and product design.
20 other people completed this guide.
Author
with
Dominik Schnabelrauch
268,208 Reputation
682 Guides authored
iFixit Member of iFixit
Staff
119 Members
72,966 Guides authored
2 Guide Comments
Would this let me remove the left and right buttons to clean under? Because if there's an easier way to clean this godforsaken design I'd rather start there ;P
CrazineX UnbounD - Reply Share
There are several additional steps required to replace the Omron switches. This requires removal of the battery to access one of the screws. Beware when removing the battery that it's easy to puncture since you have to wedge a tool beneath it to pry it away from the double-sided tape.
Flabber Gasted - Reply Share
Past 24 Hours: 15
Past 7 Days: 109
Past 30 Days: 432
All Time: 37,864
