Up to 20% off select tools
How to Open and Clean a Steam Machine (2026)
Views: 1.2K
View statistics:
Past 24 Hours:
8
Past 7 Days:
74
Past 30 Days:
313
All Time:
1,207
Comments: 3
3 comments on steps.
Completed: 0
Favorites: 0
Time Required: 1 - 3 hours
Difficulty: Moderate
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
OEM Guide
iFixit collaborated with the manufacturer to make this guide.
Tools
Introduction
Go to step 1 ↓
Follow this guide to open up and deep-clean dust and debris out of the fan, grilles, and vents of your Valve Steam Machine (2026).
If your console is loud, overheating, or underperforming, it may have built-up dust in the cooling fan, heatsink, or main vents.
If your Steam Machine lives in a cabinet with limited airflow, consider opening the door while gaming or moving it out to open air. If your console is on the ground, it may suck in extra dust, dirt, or hair and limit its ability to keep cool.
    1. How to Open and Clean a Steam Machine (2026), Before you begin: step 1, image 1 of 3 How to Open and Clean a Steam Machine (2026), Before you begin: step 1, image 2 of 3 How to Open and Clean a Steam Machine (2026), Before you begin: step 1, image 3 of 3
      • Before you begin this repair:
      • Power down your Steam Machine and disconnect the power cable.
      • Unplug any remaining cables or accessories from all ports.
      • If you have a microSD card installed, remove it. Otherwise, it may break during this procedure.
      Ask FixBot
    1. How to Open and Clean a Steam Machine (2026), Reposition the Steam Machine: step 2, image 1 of 1
      • Reposition the Steam Machine so the bottom is facing up.
      Ask FixBot
    2. How to Open and Clean a Steam Machine (2026), Remove the feet: step 3, image 1 of 3 How to Open and Clean a Steam Machine (2026), Remove the feet: step 3, image 2 of 3 How to Open and Clean a Steam Machine (2026), Remove the feet: step 3, image 3 of 3
      • Use a T8 Torx screwdriver to remove the four rubber feet.
      Ask FixBot
    1. How to Open and Clean a Steam Machine (2026), Reposition the Steam Machine: step 4, image 1 of 1
      • Reposition the Steam Machine so the back panel is facing up.
      Ask FixBot
    2. How to Open and Clean a Steam Machine (2026), Loosen the back panel screws: step 5, image 1 of 2 How to Open and Clean a Steam Machine (2026), Loosen the back panel screws: step 5, image 2 of 2
      • Use a T8 Torx screwdriver to fully loosen the two captive screws securing the back panel.
      Ask FixBot
    3. How to Open and Clean a Steam Machine (2026), Remove the back panel: step 6, image 1 of 3 How to Open and Clean a Steam Machine (2026), Remove the back panel: step 6, image 2 of 3 How to Open and Clean a Steam Machine (2026), Remove the back panel: step 6, image 3 of 3
      • The back panel is secured by two hinge clips near the bottom corners and two locking clips on the sides.
      • Lift the top edge of the panel (near the screws) until the two locking clips release.
      • If you're having trouble getting an initial grip on the panel, use a spudger to lift it enough to grab with your fingers.
      • Slide the panel towards the top edge and lift to remove it.
      Ask FixBot
    4. How to Open and Clean a Steam Machine (2026), Remove the inner assembly screws: step 7, image 1 of 2 How to Open and Clean a Steam Machine (2026), Remove the inner assembly screws: step 7, image 2 of 2
      • Use a T8 Torx screwdriver to remove the two 7.3 mm‑long screws securing the inner assembly.
      Ask FixBot
    5. How to Open and Clean a Steam Machine (2026), Remove the inner assembly: step 8, image 1 of 3 How to Open and Clean a Steam Machine (2026), Remove the inner assembly: step 8, image 2 of 3 How to Open and Clean a Steam Machine (2026), Remove the inner assembly: step 8, image 3 of 3
      • After removal, don't lay the inner assembly down on the microSD and USB ports. These ports are fragile and shouldn't have the weight of the assembly resting on them.
      • Grip the inner assembly under the fan and lift it straight up and out of the shell.
      • Set the inner assembly down so the SSD is on top.
      Ask FixBot
    1. How to Open and Clean a Steam Machine (2026), Reposition the inner assembly: step 9, image 1 of 1
      • Spin the inner assembly so the fan faces you.
      Ask FixBot
    2. How to Open and Clean a Steam Machine (2026), Remove the cable cover screws: step 10, image 1 of 2 How to Open and Clean a Steam Machine (2026), Remove the cable cover screws: step 10, image 2 of 2
      • Use a T8 Torx screwdriver to remove the 5.1 mm‑long screw securing the rear USB and Ethernet port cable cover.
      Ask FixBot
    3. How to Open and Clean a Steam Machine (2026), Remove the cable cover: step 11, image 1 of 2 How to Open and Clean a Steam Machine (2026), Remove the cable cover: step 11, image 2 of 2
      • Remove the cable cover.
      • During reassembly, make sure the tab on the edge of the cable cover slides into its cutout in the fan.
      Ask FixBot
    4. How to Open and Clean a Steam Machine (2026), Disconnect the board: step 12, image 1 of 2 How to Open and Clean a Steam Machine (2026), Disconnect the board: step 12, image 2 of 2
      • Use the flat end of a spudger to pry up and disconnect the board's press connector.
      Ask FixBot
    5. How to Open and Clean a Steam Machine (2026), Remove the board screw: step 13, image 1 of 2 How to Open and Clean a Steam Machine (2026), Remove the board screw: step 13, image 2 of 2
      • Use a T8 Torx screwdriver to remove the 5.1 mm‑long screw securing the rear USB and Ethernet port board.
      Ask FixBot
    6. How to Open and Clean a Steam Machine (2026), Remove the board: step 14, image 1 of 2 How to Open and Clean a Steam Machine (2026), Remove the board: step 14, image 2 of 2
      • Slide the board straight away fron the inner assembly to remove it.
      Ask FixBot
    1. How to Open and Clean a Steam Machine (2026), Reposition the inner assembly: step 15, image 1 of 2 How to Open and Clean a Steam Machine (2026), Reposition the inner assembly: step 15, image 2 of 2
      • Reposition the inner assembly so the antenna marked AUX ANT is facing up.
      Ask FixBot
    2. How to Open and Clean a Steam Machine (2026), Heat the auxiliary antenna: step 16, image 1 of 3 How to Open and Clean a Steam Machine (2026), Heat the auxiliary antenna: step 16, image 2 of 3 How to Open and Clean a Steam Machine (2026), Heat the auxiliary antenna: step 16, image 3 of 3
      • Mild adhesive secures the auxiliary antenna to the fan. Heating the antenna softens the adhesive, making it easier to separate. If you don't want to remove the antennas from the fan, you can disconnect and de-route them.
      • Lay a heated iOpener on the auxiliary antenna for two minutes.
      • Check out this guide for instruction on heating an iOpener.
      • Alternatively, you can use a hair dryer to soften the adhesive. For tips on using a hair dryer without accidentally melting plastic, check out this guide.
      Ask FixBot
    3. How to Open and Clean a Steam Machine (2026), Separate the auxiliary antenna: step 17, image 1 of 3 How to Open and Clean a Steam Machine (2026), Separate the auxiliary antenna: step 17, image 2 of 3 How to Open and Clean a Steam Machine (2026), Separate the auxiliary antenna: step 17, image 3 of 3
      Tool used on this step:
      Tesa 61395 Tape
      $2.95
      Buy
      • Slide the flat end of a spudger under the antenna and lift to separate the adhesive.
      • During reassembly, the adhesive should be sticky enough to reuse. If it isn't, use thin double-sided tape to secure the antenna.
      Ask FixBot
    4. How to Open and Clean a Steam Machine (2026), De-route the auxiliary antenna: step 18, image 1 of 3 How to Open and Clean a Steam Machine (2026), De-route the auxiliary antenna: step 18, image 2 of 3 How to Open and Clean a Steam Machine (2026), De-route the auxiliary antenna: step 18, image 3 of 3
      • Guide the antenna cable out of its clips on the fan.
      Ask FixBot
    5. How to Open and Clean a Steam Machine (2026), Reposition the inner assembly: step 19, image 1 of 2 How to Open and Clean a Steam Machine (2026), Reposition the inner assembly: step 19, image 2 of 2
      • Reposition the inner assembly so the antenna marked MAIN ANT is facing up.
      Ask FixBot
    6. How to Open and Clean a Steam Machine (2026), Heat the main antenna: step 20, image 1 of 3 How to Open and Clean a Steam Machine (2026), Heat the main antenna: step 20, image 2 of 3 How to Open and Clean a Steam Machine (2026), Heat the main antenna: step 20, image 3 of 3
      • Mild adhesive secures the main antenna to the fan. Heating the antenna softens the adhesive, making it easier to separate.
      • Lay a heated iOpener on the main antenna for two minutes.
      Ask FixBot
    7. How to Open and Clean a Steam Machine (2026), Separate the main antenna: step 21, image 1 of 3 How to Open and Clean a Steam Machine (2026), Separate the main antenna: step 21, image 2 of 3 How to Open and Clean a Steam Machine (2026), Separate the main antenna: step 21, image 3 of 3
      Tesa 61395 Tape
      $2.95
      Buy
      Ask FixBot
    8. How to Open and Clean a Steam Machine (2026), De-route the main antenna: step 22, image 1 of 3 How to Open and Clean a Steam Machine (2026), De-route the main antenna: step 22, image 2 of 3 How to Open and Clean a Steam Machine (2026), De-route the main antenna: step 22, image 3 of 3
      • Guide the antenna cable out of its plastic clips.
      Ask FixBot
    9. How to Open and Clean a Steam Machine (2026), Disconnect the fan: step 23, image 1 of 3 How to Open and Clean a Steam Machine (2026), Disconnect the fan: step 23, image 2 of 3 How to Open and Clean a Steam Machine (2026), Disconnect the fan: step 23, image 3 of 3
      • The fan connector can be tricky to disconnect. Be careful: excessive force could rip the socket off the board.
      • Use a pair of angled tweezers to firmly grip the head of the fan cable connector.
      • To get the best grip, hold the tweezers close to the pointed ends.
      • Gently rock the connector side-to-side while lifting to disconnect it.
      Ask FixBot
    10. How to Open and Clean a Steam Machine (2026), Peel up the fan cable: step 24, image 1 of 2 How to Open and Clean a Steam Machine (2026), Peel up the fan cable: step 24, image 2 of 2
      • Peel up the tape securing the fan cable to the heatsink.
      Ask FixBot
    11. How to Open and Clean a Steam Machine (2026), Reposition the inner assembly: step 25, image 1 of 1
      • Reposition the inner assembly so the fan is facing you and the power cable socket is on the bottom.
      Ask FixBot
    12. How to Open and Clean a Steam Machine (2026), Remove the fan screws: step 26, image 1 of 2 How to Open and Clean a Steam Machine (2026), Remove the fan screws: step 26, image 2 of 2
      • Use a T8 Torx screwdriver to remove the two 7.3 mm‑long screws securing the fan.
      Ask FixBot
    13. How to Open and Clean a Steam Machine (2026), Remove the fan: step 27, image 1 of 2 How to Open and Clean a Steam Machine (2026), Remove the fan: step 27, image 2 of 2
      • Slide the fan straight away from the inner assembly to remove it.
      • During reassembly, make sure no cables get stuck behind the fan when sliding it back in place.
      Ask FixBot
    1. How to Open and Clean a Steam Machine (2026), Remove the front port cover screws: step 28, image 1 of 2 How to Open and Clean a Steam Machine (2026), Remove the front port cover screws: step 28, image 2 of 2
      • Use a T8 Torx screwdriver to remove the three 5.1 mm‑long screws securing the front port cover.
      Ask FixBot
    2. How to Open and Clean a Steam Machine (2026), Reposition the shell: step 29, image 1 of 1
      • Reposition the shell so the open side is facing you.
      • This allows the front port cover to unclip in the next step.
      Ask FixBot
    3. How to Open and Clean a Steam Machine (2026), Unclip the front port cover: step 30, image 1 of 3 How to Open and Clean a Steam Machine (2026), Unclip the front port cover: step 30, image 2 of 3 How to Open and Clean a Steam Machine (2026), Unclip the front port cover: step 30, image 3 of 3
      • Two plastic clips secure the front port cover to the shell.
      • Use your finger to push both clips in to release them.
      Ask FixBot
    4. How to Open and Clean a Steam Machine (2026), Remove the front port cover: step 31, image 1 of 1
      • Remove the front port cover.
      Ask FixBot
    1. How to Open and Clean a Steam Machine (2026), Remove the faceplate: step 32, image 1 of 3 How to Open and Clean a Steam Machine (2026), Remove the faceplate: step 32, image 2 of 3 How to Open and Clean a Steam Machine (2026), Remove the faceplate: step 32, image 3 of 3
      • The faceplate is held in place with four strong magnets near the corners.
      • Firmly pull the faceplate away from the shell to remove it.
      Ask FixBot
    2. How to Open and Clean a Steam Machine (2026), Only the shell remains: step 33, image 1 of 1
      • You're left with just the shell.
      Ask FixBot
    1. How to Open and Clean a Steam Machine (2026), Clean the case components: step 34, image 1 of 3 How to Open and Clean a Steam Machine (2026), Clean the case components: step 34, image 2 of 3 How to Open and Clean a Steam Machine (2026), Clean the case components: step 34, image 3 of 3
      Microfiber Cleaning Cloths
      $3.99
      Buy
      • Use a clean rag or microfiber cloth to wipe clean the front and back of all accessible case components.
      • Using an anti-static brush or a new toothbrush, clean any dust out of the grilles on the shell.
      • Blow any remaining dust out of the grilles with a small dust blower or light compressed air.
      Ask FixBot
    2. How to Open and Clean a Steam Machine (2026), Clean the port cutouts: step 35, image 1 of 3 How to Open and Clean a Steam Machine (2026), Clean the port cutouts: step 35, image 2 of 3 How to Open and Clean a Steam Machine (2026), Clean the port cutouts: step 35, image 3 of 3
      • Remove the rubber gaskets from the front port cutouts.
      • Don't forget to put these back during reassembly.
      • Use a brush and dust blower to remove dust and dirt from the port cutouts.
      Ask FixBot
    3. How to Open and Clean a Steam Machine (2026), Clean the fan: step 36, image 1 of 2 How to Open and Clean a Steam Machine (2026), Clean the fan: step 36, image 2 of 2
      • Over time, dust will build up inside the fan and on the fan blades.
      • Use a pair of tweezers or your fingers to grab loose hairs and dust clumps off of the fan.
      • Use a dust blower or light compressed air to blow remaining dust off of the fan.
      • Use a finger to keep the fan blades steady—it makes them easier to clean.
      • If there's a layer of grime on the fan blades, use soapy water on a damp rag or an isopropyl alcohol wipe to clean it off.
      Ask FixBot
    4. How to Open and Clean a Steam Machine (2026), Clean the heatsink: step 37, image 1 of 3 How to Open and Clean a Steam Machine (2026), Clean the heatsink: step 37, image 2 of 3 How to Open and Clean a Steam Machine (2026), Clean the heatsink: step 37, image 3 of 3
      • The fan draws air through the heatsink's metal fins, which can accumulate dust and dirt over time.
      • Gently slide the bristles of an anti‑static brush or new toothbrush back and forth between the metal fins to loosen any debris near the openings.
      • Use a dust blower to blow any loose dust out of the heatsink fins.
      Ask FixBot
    5. How to Open and Clean a Steam Machine (2026), Clean the power supply: step 38, image 1 of 3 How to Open and Clean a Steam Machine (2026), Clean the power supply: step 38, image 2 of 3 How to Open and Clean a Steam Machine (2026), Clean the power supply: step 38, image 3 of 3
      • Repeat the previous step to clean out the grille on the power supply (underneath the heatsink).
      • Remember: use this time to clean any other dirty internal surfaces you find before you seal your console back up. Happy gaming!
      Ask FixBot
When putting your Steam Machine back where it lives, make sure it's in an area with at least a few inches of space on all sides. If your console sits in an entertainment center, make sure at least one panel is open to provide airflow. Avoid keeping the console on carpet or other similar surfaces, as your device is more likely to suck up dirt, dust, and hair.
Author
with
Spencer Day
210,776 Reputation
1,265 Guides authored
0 Guide Comments
Past 24 Hours: 8
Past 7 Days: 74
Past 30 Days: 313
All Time: 1,207
