This guide has more recent changes. Switch to the latest unverified version.
How to Open and Clean a PlayStation 5
    1. How to Open and Clean a PlayStation 5, Remove the stand screw: step 1, image 1 of 1
      • If your PlayStation 5 is in its vertical orientation, flip it upside down so the stand is facing up.
      • If your PlayStation 5 is in its horizontal orientation, skip to Step 6.
      • Work on a flat surface to prevent your PlayStation from falling over.
      • Use a coin or a flathead screwdriver to remove the 26.5 mm-long stand screw.
      Ask FixBot
    2. How to Open and Clean a PlayStation 5, Remove the vertical stand: step 2, image 1 of 2 How to Open and Clean a PlayStation 5, Remove the vertical stand: step 2, image 2 of 2
      • Lift straight up to remove the stand.
      Ask FixBot
    3. How to Open and Clean a PlayStation 5, Store the stand screw: step 3, image 1 of 2 How to Open and Clean a PlayStation 5, Store the stand screw: step 3, image 2 of 2
      • Insert the screw into the cubby on the bottom of the stand.
      Ask FixBot
    4. How to Open and Clean a PlayStation 5, Cap the screw hole: step 4, image 1 of 3 How to Open and Clean a PlayStation 5, Cap the screw hole: step 4, image 2 of 3 How to Open and Clean a PlayStation 5, Cap the screw hole: step 4, image 3 of 3
      Tool used on this step:
      Buy
      • Use a pair of tweezers or your fingernail to remove the cap from the cubby.
      • Use your finger to press the cap into the screw hole.
      Ask FixBot
    5. How to Open and Clean a PlayStation 5, Close the cubby: step 5, image 1 of 3 How to Open and Clean a PlayStation 5, Close the cubby: step 5, image 2 of 3 How to Open and Clean a PlayStation 5, Close the cubby: step 5, image 3 of 3
      • Twist the stand counterclockwise to close the cubby.
      Ask FixBot
    6. How to Open and Clean a PlayStation 5, Remove the horizontal stand: step 6, image 1 of 2 How to Open and Clean a PlayStation 5, Remove the horizontal stand: step 6, image 2 of 2
      • If your PlayStation 5 is in its horizontal orientation, rest it on its face with the charging port facing up.
      • Lift the stand straight up to remove it.
      Ask FixBot
    1. How to Open and Clean a PlayStation 5, Remove the right faceplate: step 7, image 1 of 3 How to Open and Clean a PlayStation 5, Remove the right faceplate: step 7, image 2 of 3 How to Open and Clean a PlayStation 5, Remove the right faceplate: step 7, image 3 of 3
      • Flip the device over so that the USB and ethernet ports are on the left side from your perspective.
      • Lift up the corner of the faceplate to unclip it from the case.
      Ask FixBot
    2. How to Open and Clean a PlayStation 5: step 8, image 1 of 2 How to Open and Clean a PlayStation 5: step 8, image 2 of 2
      • While lifting up the corner, slide the faceplate towards the bottom of the device.
      • Remove the right faceplate.
      Ask FixBot
    3. How to Open and Clean a PlayStation 5, Pry up the grille: step 9, image 1 of 3 How to Open and Clean a PlayStation 5, Pry up the grille: step 9, image 2 of 3 How to Open and Clean a PlayStation 5, Pry up the grille: step 9, image 3 of 3
      • Insert the flat end of a spudger underneath the grille and into the gap above the fan.
      • Lift up with the spudger to pry the grille away from the case.
      Ask FixBot
    4. How to Open and Clean a PlayStation 5, Remove the grille: step 10, image 1 of 2 How to Open and Clean a PlayStation 5, Remove the grille: step 10, image 2 of 2
      • Lift the grille away from the case to remove it.
      Ask FixBot
    5. How to Open and Clean a PlayStation 5, Remove the fan shroud screws: step 11, image 1 of 1
      Magnetic Project Mat
      $19.95
      Buy
      • Use a TR9 Torx Security driver to remove the four screws securing the fan shroud to the case:
      • Two 23.3 mm-long screws
      • One 11.4 mm-long screw
      • One 31 mm-long screw
      • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your console.
      Ask FixBot
    6. How to Open and Clean a PlayStation 5, Remove the fan shroud: step 12, image 1 of 2 How to Open and Clean a PlayStation 5, Remove the fan shroud: step 12, image 2 of 2
      • Lift the fan shroud straight up to remove it.
      Ask FixBot
    7. How to Open and Clean a PlayStation 5, Remove the wire cover: step 13, image 1 of 3 How to Open and Clean a PlayStation 5, Remove the wire cover: step 13, image 2 of 3 How to Open and Clean a PlayStation 5, Remove the wire cover: step 13, image 3 of 3
      • Insert the flat end of a spudger beneath the black wire cover and into the gap above the fan wires.
      • Pry only on the wire cover, not on the fan wires themselves.
      • Use the spudger to peel up the wire cover until you can grip it with your fingers.
      Ask FixBot
    8. How to Open and Clean a PlayStation 5: step 14, image 1 of 3 How to Open and Clean a PlayStation 5: step 14, image 2 of 3 How to Open and Clean a PlayStation 5: step 14, image 3 of 3
      • Use your fingers to peel off the wire cover.
      Ask FixBot
    9. How to Open and Clean a PlayStation 5, Disconnect the fan: step 15, image 1 of 2 How to Open and Clean a PlayStation 5, Disconnect the fan: step 15, image 2 of 2
      • Use your fingers to grip the edges of the fan cable connector, and pull up to disconnect it from the motherboard.
      • Always pull cables by their connectors and not the wires themselves.
      Ask FixBot
    10. How to Open and Clean a PlayStation 5, Remove the fan: step 16, image 1 of 3 How to Open and Clean a PlayStation 5, Remove the fan: step 16, image 2 of 3 How to Open and Clean a PlayStation 5, Remove the fan: step 16, image 3 of 3
      • Lift the fan up and out of the case to remove it.
      Ask FixBot
    1. How to Open and Clean a PlayStation 5, Clean the fan: step 17, image 1 of 1
      Dust Blower
      $19.99
      Buy
      • Over time, dust will build up inside the fan and on the fan blades.
      • Use a pair of tweezers to grab loose hairs and dust clumps off of the fan.
      • Use a small dust blower or light compressed air to blow remaining dust off of the fan.
      • Use a finger to keep the fan blades steadyโ€”it makes them easier to clean.
      • If there's a layer of grime on the fan blades, use soapy water or isopropyl alcohol on a cotton swab to wipe them off.
      Ask FixBot
    2. How to Open and Clean a PlayStation 5, Remove the left faceplate: step 18, image 1 of 3 How to Open and Clean a PlayStation 5, Remove the left faceplate: step 18, image 2 of 3 How to Open and Clean a PlayStation 5, Remove the left faceplate: step 18, image 3 of 3
      • Lift up the corner of the faceplate with the PlayStation logo to unclip it from the case.
      • Remove the left faceplate.
      Ask FixBot
    3. How to Open and Clean a PlayStation 5, Clean the faceplates: step 19, image 1 of 1
      Microfiber Cleaning Cloths
      $3.99
      Buy
      • Use a clean rag or microfiber cloth to wipe the insides of the faceplates clean.
      Ask FixBot
    4. How to Open and Clean a PlayStation 5, Clean vents and hard-to-reach areas: step 20, image 1 of 2 How to Open and Clean a PlayStation 5, Clean vents and hard-to-reach areas: step 20, image 2 of 2
      Anti-Static Brush
      $2.99
      Buy
      • With both faceplates off, now's the time to clean everything underneath that's normally hidden.
      • Two dust ports underneath the left faceplate can catch dust over time. Use a narrow vacuum attachment to clean out the ports.
      • Depending on how dirty your console is, you might need to use a soft bristle brush to dislodge more dust and grime.
      • Using an anti-static brush or a new toothbrush, clean any dust out of hard to reach areas and off of the rear vents.
      • Use a dust blower to blow any loose dust out of the console and a cloth to wipe the vents clean.
      Ask FixBot
    5. How to Open and Clean a PlayStation 5, Clean the heatsink: step 21, image 1 of 1
      • Use a dust blower, brush, and a cloth to clean the inside of the fan cavity while the fan's removed.
      • The PS5 draws air through the heatsink fins, and they may clog with dust and debris over time.
      • If you can see dust buildup in the heatsink, use a dust blower to blow it clean.
      • Remember: use this time to clean any other dirty internal surfaces before you seal your console back up. Happy gaming!
      Ask FixBot
Disassembly or cleaning didnโ€™t go as planned? Try some basic troubleshooting, or ask our PlayStation 5 Answers community for help.
58 other people completed this guide.
Carsten Frauenheim
171,545 Reputation
441 Guides authored
iFixit Member of iFixit
Staff
121 Members
72,737 Guides authored
5 Guide Comments
How do i clean the lebron faceplate?
Hugh Johnson - Reply Share
Simple easy understandable..11/10
Stephan Mccathern - Reply Share
Is the wire cover (Step 13) just glued on? Will I be able to put it back and have it hold on when assembling again?
Delta KT - Reply Share
Excellent tutoriel sans le "bavassage" des vidรฉos ๐Ÿ‘
gilbert trevien - Reply Share
Really easy to clean ๐Ÿ‘๐Ÿปand easy to follow haven't done a deep clean since I've had it in 2020/21 can't remember when purchased. I've keeped the outside and inside clean but have never cleaned the fan yes I now that's bad ๐Ÿ˜…
Louise98 - Reply Share
Past 24 Hours: 368
Past 7 Days: 3,092
Past 30 Days: 13,057
All Time: 248,272
