How to Open a Google Pixel Watch
Views: 6.1K
View statistics:
Past 24 Hours:
2
Past 7 Days:
24
Past 30 Days:
167
All Time:
6,109
Comments: 3
1 comment on steps, 2 guide comments.
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 - 30 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
Use this guide to open your Google Pixel Watch for repairs.
For your safety, discharge the battery below 25% before disassembling your device. This reduces the risk of fire if the battery is accidentally damaged during the repair. If your battery is swollen, take appropriate precautions.
You’ll need replacement adhesive to reattach the screen when reassembling the device.
Retaining water resistance after the repair will depend on how precisely the adhesive is reapplied, but your device will lose its IP (Ingress Protection) rating.
Note: This guide was written using a GBZ4S LTE model. If you have the non-LTE version, you can still use this guide—but there might be slight visual discrepancies.
Tools
    1. How to Open a Google Pixel Watch, Remove the watch band: step 1, image 1 of 3 How to Open a Google Pixel Watch, Remove the watch band: step 1, image 2 of 3 How to Open a Google Pixel Watch, Remove the watch band: step 1, image 3 of 3
      • Before starting repairs, turn off your watch and take it off the charger.
      • Remove the watch band by pressing the band release button and sliding the band over the button while pulling it away from the watch.
      • Repeat for the other watch band.
      Ask FixBot
    2. How to Open a Google Pixel Watch, Loosen the screen adhesive: step 2, image 1 of 1
      • Heat an iOpener and apply it to the screen for about two minutes to soften the adhesive securing the screen.
      • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the watch—the screen and internal battery are both susceptible to heat damage.
      Ask FixBot
    3. How to Open a Google Pixel Watch, Insert an iFlex: step 3, image 1 of 2 How to Open a Google Pixel Watch, Insert an iFlex: step 3, image 2 of 2
      Tool used on this step:
      iFlex Opening Tool
      $11.99
      Buy
      • The thin seam between the frame and screen requires a thin metal tool—take your time and work carefully to avoid scraping or gouging the watch body or glass.
      • Insert an iFlex into the thin gap between the screen and frame, left of the digital crown.
      Ask FixBot
    4. How to Open a Google Pixel Watch, Slice the screen adhesive: step 4, image 1 of 3 How to Open a Google Pixel Watch, Slice the screen adhesive: step 4, image 2 of 3 How to Open a Google Pixel Watch, Slice the screen adhesive: step 4, image 3 of 3
      • When slicing the screen adhesive, insert the iFlex no deeper than 3 mm to prevent damaging internal components.
      • Slide the iFlex around the entire perimeter of the watch to slice all of the screen adhesive.
      Ask FixBot
    5. How to Open a Google Pixel Watch, Pry up the screen: step 5, image 1 of 2 How to Open a Google Pixel Watch, Pry up the screen: step 5, image 2 of 2
      • Remove the iFlex and reinsert it under the screen, to the right of the speaker grille.
      • Twist the iFlex to pry the screen up.
      • Don't try to fully remove the screen just yet, as it‘s still connected to the watch assembly by a delicate cable.
      Ask FixBot
    6. How to Open a Google Pixel Watch, Swing open the screen: step 6, image 1 of 3 How to Open a Google Pixel Watch, Swing open the screen: step 6, image 2 of 3 How to Open a Google Pixel Watch, Swing open the screen: step 6, image 3 of 3
      • Be careful not to strain the screen assembly cable when you open the display.
      • Swing the screen open to an upright position.
      • During reassembly, this is a good point to power on your device and test all functions before sealing it up. Be sure to power it back down completely before you continue working.
      Ask FixBot
During reassembly, apply new adhesive where it's necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
2 other people completed this guide.
Dominik Schnabelrauch
266,462 Reputation
682 Guides authored
iFixit Member of iFixit
Staff
121 Members
72,895 Guides authored
2 Guide Comments
What kind of adhesive is needed?
Rob Novak - Reply Share
Please specify the glue to be used.
Welchen Klebstoff sollen wir verwenden?
Same for front and back plates?
Michael Vogt - Reply Share
Past 24 Hours: 2
Past 7 Days: 24
Past 30 Days: 167
All Time: 6,109
