How to Open Your Logitech Signature M650 Wireless Mouse
    1. How to Open Your Logitech Signature M650 Wireless Mouse, Turn off your mouse: step 1, image 1 of 1
      • Before starting, flip the power switch on the bottom of your mouse to the left, so it's in the OFF position.
      Ask FixBot
    2. How to Open Your Logitech Signature M650 Wireless Mouse, Remove the battery cover: step 2, image 1 of 3 How to Open Your Logitech Signature M650 Wireless Mouse, Remove the battery cover: step 2, image 2 of 3 How to Open Your Logitech Signature M650 Wireless Mouse, Remove the battery cover: step 2, image 3 of 3
      • Press down on the battery cover with your thumb and slide it away from the mouse to unclip it.
      • Remove the battery cover.
      Ask FixBot
    3. How to Open Your Logitech Signature M650 Wireless Mouse, Remove the battery: step 3, image 1 of 3 How to Open Your Logitech Signature M650 Wireless Mouse, Remove the battery: step 3, image 2 of 3 How to Open Your Logitech Signature M650 Wireless Mouse, Remove the battery: step 3, image 3 of 3
      • Use your fingers to lift the end of the battery and slide it out of its recess.
      • During reassembly, slide the battery in negative (-) end first, as shown on the sticker in the recess.
      Ask FixBot
    1. How to Open Your Logitech Signature M650 Wireless Mouse, Remove the case screws: step 4, image 1 of 2 How to Open Your Logitech Signature M650 Wireless Mouse, Remove the case screws: step 4, image 2 of 2
      • Use a Phillips screwdriver to remove the two 5.5 mm‑long screws securing the two halves of the mouse together.
      Ask FixBot
    2. How to Open Your Logitech Signature M650 Wireless Mouse, Separate the two halves: step 5, image 1 of 3 How to Open Your Logitech Signature M650 Wireless Mouse, Separate the two halves: step 5, image 2 of 3 How to Open Your Logitech Signature M650 Wireless Mouse, Separate the two halves: step 5, image 3 of 3
      • The two halves of the mouse are secured by two clips near the front.
      • Hold the top half of the mouse and pull the bottom half away and down to separate it.
      • Don't try to fully separate the two halves yet—a cable still connects them.
      Ask FixBot
    3. How to Open Your Logitech Signature M650 Wireless Mouse, Reposition the top half: step 6, image 1 of 2 How to Open Your Logitech Signature M650 Wireless Mouse, Reposition the top half: step 6, image 2 of 2
      • Reposition the top half of the mouse so you can access its connector near the back.
      Ask FixBot
    4. How to Open Your Logitech Signature M650 Wireless Mouse, Disconnect the top half: step 7, image 1 of 3 How to Open Your Logitech Signature M650 Wireless Mouse, Disconnect the top half: step 7, image 2 of 3 How to Open Your Logitech Signature M650 Wireless Mouse, Disconnect the top half: step 7, image 3 of 3
      • Use a pair of angled tweezers to firmly grip the base of the connector, just below its notches.
      • Hold your tweezers closer to the tips to get a better grip.
      • Gently rock the connector side‑to‑side and pull straight up to disconnect it.
      Ask FixBot
    5. How to Open Your Logitech Signature M650 Wireless Mouse, Remove the top half: step 8, image 1 of 1
      • Remove the top half of the mouse from the bottom half.
      Ask FixBot
Reuse or Recycle—Never put discarded electronic parts in household waste. Visit Logitech Recycling to find your nearest recycling points, including the option to mail back old devices to Logitech for free if there’s no convenient solution in your area. You can also take your e-waste to any R2 or e-Stewards certified recycler. And don’t let good working parts or repaired devices die a slow death in your sock drawer—pass them along to someone who can use them.
Share your experience—Leave a comment here or send your feedback directly to Logitech at repair@logitech.com to help shape future repair guides and product design.
Spencer Day
201,496 Reputation
1,244 Guides authored
0 Guide Comments
Past 24 Hours: 15
Past 7 Days: 99
Past 30 Days: 437
All Time: 2,831
