How to Open Your Logitech MX Anywhere 3 for Mac
  1. How to Open Your Logitech MX Anywhere 3 for Mac, Prepare the mouse for disassembly: step 1, image 1 of 2 How to Open Your Logitech MX Anywhere 3 for Mac, Prepare the mouse for disassembly: step 1, image 2 of 2
    • Slide the mouse's power switch to the OFF position and unplug any cables.
    • Flip the mouse over so the feet are facing up.
    • The unique shape of some mice can prevent them from laying flat. If you need to, lay your mouse on a soft towel to prevent wobble.
  2. How to Open Your Logitech MX Anywhere 3 for Mac, Soften the mouse feet adhesive: step 2, image 1 of 1
    • If you're planning to reuse your existing mouse feet, the adhesive needs to be thoroughly heated to cleanly remove them.
    • Heat an iOpener and lay it on the mouse feet for about two minutes to soften the adhesive.
    • Alternatively, you can use a hair dryer to soften the mouse feet adhesive.
    • When using a hair dryer, don't heat the feet for more than a couple seconds at a time—anything hotter than just warm to the touch risks melting or warping the plastic case.
  3. How to Open Your Logitech MX Anywhere 3 for Mac, Disassembly information: step 3, image 1 of 3 How to Open Your Logitech MX Anywhere 3 for Mac, Disassembly information: step 3, image 2 of 3 How to Open Your Logitech MX Anywhere 3 for Mac, Disassembly information: step 3, image 3 of 3
    • While you wait for the adhesive to soften, note the following:
    • There are small gaps in the rims surrounding each foot. This is where to insert your tool when peeling up the feet.
  4. How to Open Your Logitech MX Anywhere 3 for Mac, Remove the feet: step 4, image 1 of 3 How to Open Your Logitech MX Anywhere 3 for Mac, Remove the feet: step 4, image 2 of 3 How to Open Your Logitech MX Anywhere 3 for Mac, Remove the feet: step 4, image 3 of 3
    • Push the tip of an opening pick (or spudger) underneath the mouse foot, into the gap in the rim.
    • Go slowly, and make sure the pick slides underneath both the foot and its adhesive pad—these layers separate easily.
    • If you plan on reusing your mouse feet, be careful not to crease them or separate them from their adhesive pads.
    • Slide your pick under the foot and lift to remove it.
    • Repeat the process to remove the three remaining mouse feet. If you're having trouble sliding the tool under a foot, reheat it and try again.
    • To install new mouse feet:
    • Use a pair of tweezers or a spudger to remove any large chunks of leftover adhesive. Thoroughly clean the bottom of the mouse with isopropyl alcohol and a lint-free of microfiber cloth. Allow the surface to dry completely.
    • Peel your new mouse feet off their adhesive liners and press them firmly into place.
  5. How to Open Your Logitech MX Anywhere 3 for Mac, Remove the case screws: step 5, image 1 of 2 How to Open Your Logitech MX Anywhere 3 for Mac, Remove the case screws: step 5, image 2 of 2
    • Use a Phillips screwdriver to remove the four 4.3 mm‑long screws securing the two halves of the mouse together.
  6. How to Open Your Logitech MX Anywhere 3 for Mac, Open the mouse: step 6, image 1 of 3 How to Open Your Logitech MX Anywhere 3 for Mac, Open the mouse: step 6, image 2 of 3 How to Open Your Logitech MX Anywhere 3 for Mac, Open the mouse: step 6, image 3 of 3
    • Gently lift the top shell off the mouse up and flip it over the right edge.
    • Don't try to fully remove the top shell yet—a cable connects it to the lower half.
  7. How to Open Your Logitech MX Anywhere 3 for Mac, Disconnect the interconnect cable: step 7, image 1 of 2 How to Open Your Logitech MX Anywhere 3 for Mac, Disconnect the interconnect cable: step 7, image 2 of 2
    • Use the point of a spudger or a clean fingernail to flip up the small, hinged locking flap on the interconnect cable ZIF connector (located on the underside of the top shell).
  8. How to Open Your Logitech MX Anywhere 3 for Mac, Separate the cable adhesive: step 8, image 1 of 2 How to Open Your Logitech MX Anywhere 3 for Mac, Separate the cable adhesive: step 8, image 2 of 2
    • There may be a small piece of adhesive securing the interconnect cable to the board on the top shell, right where the cable goes into its socket.
    • Apply a heated iOpener to the board on the underside of the mouse's top half for two minutes.
    • Gently slide the tip of an opening pick under the cable to separate its adhesive.
  9. How to Open Your Logitech MX Anywhere 3 for Mac: step 9, image 1 of 2 How to Open Your Logitech MX Anywhere 3 for Mac: step 9, image 2 of 2
    • Use your fingers or tweezers to pull the cable straight out of its socket.
    • During reassembly, insert the cable with its blue tab facing up, then flip down the locking flap.
  10. How to Open Your Logitech MX Anywhere 3 for Mac, Remove the top half of the mouse: step 10, image 1 of 1
    • Remove the top shell.
Clay Eickemeyer
103,116 Reputation
476 Guides authored
Guide Team Member of Guide Team
Staff
10 Members
17,771 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 15
Past 30 Days: 76
All Time: 1,456
