Up to 20% off select tools
How to Open Your Logitech M220
Views: 2.8K
View statistics:
Past 24 Hours:
9
Past 7 Days:
122
Past 30 Days:
553
All Time:
2,815
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 10 - 15 minutes
Difficulty: Moderate
OEM Guide
iFixit collaborated with the manufacturer to make this guide.
Logitech
Logitech and iFixit are working together to help people repair their Logitech devices.
Tools
Introduction
Go to step 1 ↓
Follow this guide to open your Logitech M220 silent wireless mouse.
Opening your mouse gives you access to clean its internals, troubleshoot mechanical problems, or replace a part.
    1. How to Open Your Logitech M220, Turn off your mouse: step 1, image 1 of 1
      • Before starting, slide the power switch on the bottom of your mouse to the left, so it's in the OFF position.
      Ask FixBot
    2. How to Open Your Logitech M220, Remove the battery cover: step 2, image 1 of 3 How to Open Your Logitech M220, Remove the battery cover: step 2, image 2 of 3 How to Open Your Logitech M220, Remove the battery cover: step 2, image 3 of 3
      • Press down on the battery cover and slide it away from the mouse to remove it.
      Ask FixBot
    3. How to Open Your Logitech M220, Remove the battery: step 3, image 1 of 3 How to Open Your Logitech M220, Remove the battery: step 3, image 2 of 3 How to Open Your Logitech M220, Remove the battery: step 3, image 3 of 3
      • Use your fingers to lift the end of the battery and slide it out of its recess.
      • During reassembly, slide the battery in negative (-) end first, as shown on the engravings in the recess.
      Ask FixBot
    1. How to Open Your Logitech M220, Remove the case screw: step 4, image 1 of 2 How to Open Your Logitech M220, Remove the case screw: step 4, image 2 of 2
      • Use a Phillips screwdriver to remove the 5.4 mm‑long screw from the battery recess.
      Ask FixBot
    2. How to Open Your Logitech M220, Separate the two halves: step 5, image 1 of 3 How to Open Your Logitech M220, Separate the two halves: step 5, image 2 of 3 How to Open Your Logitech M220, Separate the two halves: step 5, image 3 of 3
      • The two halves of the mouse are secured by clips near the front.
      • Hold the bottom half of the mouse steady and pull the top half away and towards the rear to remove it.
      • During reassembly, slide the clips near the front of the mouse into place.
      Ask FixBot
Reuse or Recycle—Never put discarded electronic parts in household waste. Visit Logitech Recycling to find your nearest recycling points, including the option to mail back old devices to Logitech for free if there’s no convenient solution in your area. You can also take your e-waste to any R2 or e-Stewards certified recycler. And don’t let good working parts or repaired devices die a slow death in your sock drawer—pass them along to someone who can use them.
Share your experience—Leave a comment here or send your feedback directly to Logitech at repair@logitech.com to help shape future repair guides and product design.
Spencer Day
210,830 Reputation
1,265 Guides authored
0 Guide Comments
Past 24 Hours: 9
Past 7 Days: 122
Past 30 Days: 553
All Time: 2,815
