How to Open Your Logitech K540 Wireless Keyboard
Views: 2.3K
View statistics:
Past 24 Hours:
14
Past 7 Days:
71
Past 30 Days:
281
All Time:
2,328
Comments: 0
Go to guide comments
Completed: 4
4 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 30 minutes - 1 hour
Difficulty: Moderate
OEM Guide
iFixit collaborated with the manufacturer to make this guide.
Logitech
Logitech and iFixit are working together to help people repair their Logitech devices.
Introduction
Go to step 1 ↓
Follow this guide to open your Logitech K540 wireless keyboard.
Opening your keyboard gives you access to clean its internals, troubleshoot mechanical problems, or replace a part.
Before starting this repair, note that opening the keyboard requires removing the Logitech sticker on the bottom—it's very hard to do this without damaging the sticker.
Tools
    1. How to Open Your Logitech K540 Wireless Keyboard, Prepare your keyboard for disassembly: step 1, image 1 of 2 How to Open Your Logitech K540 Wireless Keyboard, Prepare your keyboard for disassembly: step 1, image 2 of 2
      • Slide the power switch on the top right corner to the OFF position.
      • Flip your keyboard over and lay it down so the edge with the two tilt legs is closest to you.
      • If your work surface might scratch the keyboard, place a soft towel under it.
      Ask FixBot
    1. How to Open Your Logitech K540 Wireless Keyboard, Remove the battery cover: step 2, image 1 of 3 How to Open Your Logitech K540 Wireless Keyboard, Remove the battery cover: step 2, image 2 of 3 How to Open Your Logitech K540 Wireless Keyboard, Remove the battery cover: step 2, image 3 of 3
      • Use your finger to pull the tab near the middle of the battery cover inward, towards the center of the cover.
      • With the tab pulled in, lift and remove the cover.
      Ask FixBot
    2. How to Open Your Logitech K540 Wireless Keyboard, Remove the batteries: step 3, image 1 of 3 How to Open Your Logitech K540 Wireless Keyboard, Remove the batteries: step 3, image 2 of 3 How to Open Your Logitech K540 Wireless Keyboard, Remove the batteries: step 3, image 3 of 3
      • Use your finger to lift the edge of the outer battery and remove it.
      • Slide the second battery out of the recess and remove it.
      • During reassembly, slide the batteries in negative (-) end first, as shown in the recess.
      Ask FixBot
    1. How to Open Your Logitech K540 Wireless Keyboard, Remove the three feet: step 4, image 1 of 3 How to Open Your Logitech K540 Wireless Keyboard, Remove the three feet: step 4, image 2 of 3 How to Open Your Logitech K540 Wireless Keyboard, Remove the three feet: step 4, image 3 of 3
      • Light adhesive secures the three rubber feet along the edge of the keyboard. If you're having trouble removing them, use an iOpener or hair dryer to lightly heat them.
      • Insert the point of a spudger under an end of the foot.
      • Push the spudger underneath the foot and lift until you can grip it with your fingers.
      • Peel the foot up and remove it.
      Ask FixBot
    2. How to Open Your Logitech K540 Wireless Keyboard: step 5, image 1 of 2 How to Open Your Logitech K540 Wireless Keyboard: step 5, image 2 of 2
      • Repeat the previous step to remove the two remaining feet.
      Ask FixBot
    1. How to Open Your Logitech K540 Wireless Keyboard, Remove the USB receiver: step 6, image 1 of 3 How to Open Your Logitech K540 Wireless Keyboard, Remove the USB receiver: step 6, image 2 of 3 How to Open Your Logitech K540 Wireless Keyboard, Remove the USB receiver: step 6, image 3 of 3
      • If you have a USB receiver stored in the battery compartment, use your fingers to remove it.
      Ask FixBot
    2. How to Open Your Logitech K540 Wireless Keyboard, Heat the Logitech sticker: step 7, image 1 of 2 How to Open Your Logitech K540 Wireless Keyboard, Heat the Logitech sticker: step 7, image 2 of 2
      • The Logitech sticker covers two screws and is very hard to cleanly remove. If you don't mind damaging the sticker, you can pierce through it with your screwdriver and skip the next two steps.
      • Heat an iOpener and lay it on the Logitech sticker for two minutes to soften the adhesive.
      • Alternatively, you can use a hair dryer to heat the sticker.
      • When using a hair dryer, don't heat one area of the sticker for more than a couple seconds at a time, or you risk melting or warping the plastic case.
      Ask FixBot
    3. How to Open Your Logitech K540 Wireless Keyboard, Peel up the Logitech sticker: step 8, image 1 of 2 How to Open Your Logitech K540 Wireless Keyboard, Peel up the Logitech sticker: step 8, image 2 of 2
      • The sticker is very hard to remove without damaging it. You'll need to peel slowly and constantly reheat it to have the best shot of a clean removal.
      • Use the flat end of a spudger to scrape up a corner of the sticker until you can grip it with your fingers.
      • Peel the sticker up very slowly, pausing to reheat it if you feel any resistance. If the sticker starts to rip, stop and try at a different corner.
      • If the sticker tears or won’t come off cleanly, either pierce it with your screwdriver in the next step or use a spudger and isopropyl alcohol to scrape off all the remnants.
      Ask FixBot
    4. How to Open Your Logitech K540 Wireless Keyboard, Remove the case screws: step 9, image 1 of 2 How to Open Your Logitech K540 Wireless Keyboard, Remove the case screws: step 9, image 2 of 2
      • Use a Phillips screwdriver to remove the sixteen 7 mm‑long screws securing the two halves of the keyboard together.
      Ask FixBot
    5. How to Open Your Logitech K540 Wireless Keyboard, Flip your keyboard over: step 10, image 1 of 1
      • Flip your keyboard over and lay it down so the top edge (with the logi logo) is facing you.
      Ask FixBot
    6. How to Open Your Logitech K540 Wireless Keyboard, Release the clips: step 11, image 1 of 3 How to Open Your Logitech K540 Wireless Keyboard, Release the clips: step 11, image 2 of 3 How to Open Your Logitech K540 Wireless Keyboard, Release the clips: step 11, image 3 of 3
      • Insert the long edge of an opening pick in the seam between the two halves of the keyboard, by the corner near the power button.
      • Pry up the top half of the keyboard to release the clips.
      • You should feel and hear a "click" as the clip releases.
      • Leave the pick inserted for the next step.
      Ask FixBot
    7. How to Open Your Logitech K540 Wireless Keyboard: step 12, image 1 of 3 How to Open Your Logitech K540 Wireless Keyboard: step 12, image 2 of 3 How to Open Your Logitech K540 Wireless Keyboard: step 12, image 3 of 3
      • During this step, keep the opening pick flat to help release the clips.
      • Slide the opening pick around the perimeter of the keyboard to release the remaining clips.
      • You should feel and hear "clicks" as the pick slides along each section. If you don't, slide the pick along the section again—the clips didn't release.
      Ask FixBot
    8. How to Open Your Logitech K540 Wireless Keyboard, Remove the  top half: step 13, image 1 of 3 How to Open Your Logitech K540 Wireless Keyboard, Remove the  top half: step 13, image 2 of 3 How to Open Your Logitech K540 Wireless Keyboard, Remove the  top half: step 13, image 3 of 3
      • Use both hands to lift the top half of the keyboard off the bottom half.
      • During reassembly, set the keyboard’s top half in place and press firmly around the edges to engage all clips. Check for gaps and re-engage any loose clips.
      Ask FixBot
    9. How to Open Your Logitech K540 Wireless Keyboard, Membrane information: step 14, image 1 of 2 How to Open Your Logitech K540 Wireless Keyboard, Membrane information: step 14, image 2 of 2
      • During reassembly:
      • Make sure the two membranes (one plastic, one silicone) are properly aligned before putting your keyboard back together.
      • There are many alignment posts and cutouts on each membrane to help properly orient them.
      Ask FixBot
Reuse or Recycle—Never put discarded electronic parts in household waste. Visit Logitech Recycling to find your nearest recycling points, including the option to mail back old devices to Logitech for free if there’s no convenient solution in your area. You can also take your e-waste to any R2 or e-Stewards certified recycler. And don’t let good working parts or repaired devices die a slow death in your sock drawer—pass them along to someone who can use them.
Share your experience—Leave a comment here or send your feedback directly to Logitech at repair@logitech.com to help shape future repair guides and product design.
4 other people completed this guide.
Spencer Day
207,725 Reputation
1,266 Guides authored
0 Guide Comments
Past 24 Hours: 14
Past 7 Days: 71
Past 30 Days: 281
All Time: 2,328
