How to Open Your Logitech K235 Wireless Keyboard
    1. How to Open Your Logitech K235 Wireless Keyboard, Flip your keyboard over: step 1, image 1 of 1
      • Flip your keyboard over so the feet are facing up.
      • If your work surface might scratch the keyboard, place a soft towel under it.
      Ask FixBot
    2. How to Open Your Logitech K235 Wireless Keyboard, Remove the battery cover: step 2, image 1 of 3 How to Open Your Logitech K235 Wireless Keyboard, Remove the battery cover: step 2, image 2 of 3 How to Open Your Logitech K235 Wireless Keyboard, Remove the battery cover: step 2, image 3 of 3
      • Use your fingers to press down on the battery cover and slide it away from the keyboard to remove it.
      Ask FixBot
    3. How to Open Your Logitech K235 Wireless Keyboard, Remove the batteries: step 3, image 1 of 3 How to Open Your Logitech K235 Wireless Keyboard, Remove the batteries: step 3, image 2 of 3 How to Open Your Logitech K235 Wireless Keyboard, Remove the batteries: step 3, image 3 of 3
      • Use your fingers to remove the two batteries.
      • During reassembly, insert the AAA batteries according to the marking in the recess.
      Ask FixBot
    1. How to Open Your Logitech K235 Wireless Keyboard, Remove the feet: step 4, image 1 of 1
      • While you can remove the feet without heating them, doing so gives you a better chance of a clean removal.
      • Heat an iOpener and lay it on one of the feet for one minute.
      • Alternatively, you can use a hair dryer on Low to heat the feet.
      • If using a hair dryer, only heat the feet a few seconds at a time to avoid warping the plastic.
      Ask FixBot
    2. How to Open Your Logitech K235 Wireless Keyboard: step 5, image 1 of 3 How to Open Your Logitech K235 Wireless Keyboard: step 5, image 2 of 3 How to Open Your Logitech K235 Wireless Keyboard: step 5, image 3 of 3
      • Slide the point of a spudger under the foot and lift until you can grip the foot with your fingers.
      • Use your fingers to slowly peel up and remove the foot.
      • Repeat the heating and removal process on the two remaining feet.
      • During reassembly, use a spudger to scrape up and remove any leftover bits of adhesive from the foot recesses before pressing the feet firmly into place.
      Ask FixBot
    3. How to Open Your Logitech K235 Wireless Keyboard, Lift the tilt legs: step 6, image 1 of 3 How to Open Your Logitech K235 Wireless Keyboard, Lift the tilt legs: step 6, image 2 of 3 How to Open Your Logitech K235 Wireless Keyboard, Lift the tilt legs: step 6, image 3 of 3
      • Use your fingers to lift both tilt legs, so you can access the screws underneath.
      Ask FixBot
    4. How to Open Your Logitech K235 Wireless Keyboard, Remove the case screws: step 7, image 1 of 2 How to Open Your Logitech K235 Wireless Keyboard, Remove the case screws: step 7, image 2 of 2
      • Use a Phillips screwdriver to remove the twelve 7.1 mm‑long screws securing the keyboard together.
      Ask FixBot
    5. How to Open Your Logitech K235 Wireless Keyboard, Insert a spudger: step 8, image 1 of 3 How to Open Your Logitech K235 Wireless Keyboard, Insert a spudger: step 8, image 2 of 3 How to Open Your Logitech K235 Wireless Keyboard, Insert a spudger: step 8, image 3 of 3
      • Insert the flat end of a spudger in the seam between the two halves of the keyboard, near the center of the bottom edge.
      • Gently pry the two halves apart to release the clips.
      Ask FixBot
    6. How to Open Your Logitech K235 Wireless Keyboard, Release the clips: step 9, image 1 of 3 How to Open Your Logitech K235 Wireless Keyboard, Release the clips: step 9, image 2 of 3 How to Open Your Logitech K235 Wireless Keyboard, Release the clips: step 9, image 3 of 3
      • Keep the spudger flat to the keyboard and slide it around the perimeter of the keyboard to release all the clips.
      • You should feel and hear the clips release. If you don't, slide the spudger along the section again and pry until the clips release.
      • During reassembly, put the bottom half of the keyboard into place and press firmly around the perimeter to engage the clips.
      Ask FixBot
    7. How to Open Your Logitech K235 Wireless Keyboard, Open the keyboard: step 10, image 1 of 2 How to Open Your Logitech K235 Wireless Keyboard, Open the keyboard: step 10, image 2 of 2
      • Gently hold both halves of the keyboard together and flip it over so the keys are facing up.
      • This reduces the risk of misaligning the keyboard's internal membranes when separating the keyboard.
      • Remove the top half of the keyboard.
      Ask FixBot
Reuse or Recycle—Never put discarded electronic parts in household waste. Visit Logitech Recycling to find your nearest recycling points, including the option to mail back old devices to Logitech for free if there’s no convenient solution in your area. You can also take your e-waste to any R2 or e-Stewards certified recycler. And don’t let good working parts or repaired devices die a slow death in your sock drawer—pass them along to someone who can use them.
Share your experience—Leave a comment here or send your feedback directly to Logitech at repair@logitech.com to help shape future repair guides and product design.
Spencer Day
201,109 Reputation
1,243 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 24
Past 30 Days: 116
All Time: 631
