How to Open Your Logitech G502 Hero Mouse
  1. How to Open Your Logitech G502 Hero Mouse, Prepare your mouse for disassembly: step 1, image 1 of 1
    • Before starting your repair, unplug the mouse.
    • Throughout your repair, it may be helpful to lay your mouse on a soft cloth to stabilize it and prevent damage while you work.
    Ask FixBot
  2. How to Open Your Logitech G502 Hero Mouse, Remove the feet: step 2, image 1 of 2 How to Open Your Logitech G502 Hero Mouse, Remove the feet: step 2, image 2 of 2
    • The feet are secured to the bottom of the mouse with adhesive. In order to cleanly remove them, the adhesive needs to be thoroughly heated.
    • Heat an iOpener and lay it on the mouse feet for one minute to heat the adhesive.
    • Alternatively, you can use a hair dryer on the Low heat setting to soften the adhesive.
    • If you're using a hair dryer, only heat the feet a few seconds at a time or you may warp the plastic shell.
    Ask FixBot
  3. How to Open Your Logitech G502 Hero Mouse: step 3, image 1 of 3 How to Open Your Logitech G502 Hero Mouse: step 3, image 2 of 3 How to Open Your Logitech G502 Hero Mouse: step 3, image 3 of 3
    • The feet have two layers—a rubberized one and an adhesive pad underneath.
    • If you're reusing the feet, be very careful not to separate the two layers or damage the feet.
    • Carefully slide the point of a spudger under the large foot near the front of the mouse, making sure it goes under both the foot and its adhesive pad.
    • The foot recesses have a small notch that makes it easier to slide your spudger under.
    • Gently slide the spudger farther under the foot and lift until you can grip the pad with your fingers.
    Ask FixBot
  4. How to Open Your Logitech G502 Hero Mouse: step 4, image 1 of 3 How to Open Your Logitech G502 Hero Mouse: step 4, image 2 of 3 How to Open Your Logitech G502 Hero Mouse: step 4, image 3 of 3
    • Peel up and remove the foot.
    • If the rubber layer separates from its adhesive pad, use the same process to remove the pad.
    Ask FixBot
  5. How to Open Your Logitech G502 Hero Mouse: step 5, image 1 of 3 How to Open Your Logitech G502 Hero Mouse: step 5, image 2 of 3 How to Open Your Logitech G502 Hero Mouse: step 5, image 3 of 3
    Ask FixBot
  6. How to Open Your Logitech G502 Hero Mouse, Reassembly information: step 6, image 1 of 3 How to Open Your Logitech G502 Hero Mouse, Reassembly information: step 6, image 2 of 3 How to Open Your Logitech G502 Hero Mouse, Reassembly information: step 6, image 3 of 3
    • To install a new foot:
    • If any of the feet got damaged during removal or separated from their adhesive pads, replace them.
    • Use a spudger to carefully scrape up and remove any remaining adhesive bits.
    • Use isopropyl alcohol and a microfiber cloth to thoroughly clean all adhesive residue from the foot recesses. Allow the surface to completely dry.
    • Remove the feet from their backing and firmly press them into place.
    Ask FixBot
  7. How to Open Your Logitech G502 Hero Mouse, Open your mouse: step 7, image 1 of 3 How to Open Your Logitech G502 Hero Mouse, Open your mouse: step 7, image 2 of 3 How to Open Your Logitech G502 Hero Mouse, Open your mouse: step 7, image 3 of 3
    • Lift the weight door by its tab and remove it.
    • If you have weights in the compartment, remove them.
    Ask FixBot
  8. How to Open Your Logitech G502 Hero Mouse: step 8, image 1 of 2 How to Open Your Logitech G502 Hero Mouse: step 8, image 2 of 2
    • Use a Phillips screwdriver to remove the four 5.5 mm‑long screws securing the bottom shell.
    Ask FixBot
  9. How to Open Your Logitech G502 Hero Mouse: step 9, image 1 of 3 How to Open Your Logitech G502 Hero Mouse: step 9, image 2 of 3 How to Open Your Logitech G502 Hero Mouse: step 9, image 3 of 3
    • Tight plastic clips secure the top and bottom shells. During the next few steps you should feel and hear "clicks" as the clips release.
    • Insert the flat end of a spudger between the top and bottom shells, near the back of the mouse.
    • Twist the spudger to unclip the shells.
    Ask FixBot
  10. How to Open Your Logitech G502 Hero Mouse: step 10, image 1 of 3 How to Open Your Logitech G502 Hero Mouse: step 10, image 2 of 3 How to Open Your Logitech G502 Hero Mouse: step 10, image 3 of 3
    • Insert the flat end of a spudger between the textured edge of the top and bottom shells, near the back of the mouse.
    • Slide the spudger towards the front of the mouse and intermittently twist, stopping near the screw hole.
    • Leave the spudger inserted for the next step.
    Ask FixBot
  11. How to Open Your Logitech G502 Hero Mouse: step 11, image 1 of 3 How to Open Your Logitech G502 Hero Mouse: step 11, image 2 of 3 How to Open Your Logitech G502 Hero Mouse: step 11, image 3 of 3
    • Push the spudger into the mouse and twist to unclip the shells.
    Ask FixBot
  12. How to Open Your Logitech G502 Hero Mouse: step 12, image 1 of 3 How to Open Your Logitech G502 Hero Mouse: step 12, image 2 of 3 How to Open Your Logitech G502 Hero Mouse: step 12, image 3 of 3
    • Slide the spudger towards the thumb rest and push in to unclip the shells.
    Ask FixBot
  13. How to Open Your Logitech G502 Hero Mouse: step 13, image 1 of 3 How to Open Your Logitech G502 Hero Mouse: step 13, image 2 of 3 How to Open Your Logitech G502 Hero Mouse: step 13, image 3 of 3
    • Insert the flat end of a spudger between the top and bottom shells, near the G8 and DPI shift () buttons at the front of the mouse.
    • Pry up with the spudger and push the shells apart to unclip them.
    • Unclipping this part of the mouse is tricky and may take a few tries. Be patient and don't pry too hard, or you may break one of the clips.
    Ask FixBot
  14. How to Open Your Logitech G502 Hero Mouse: step 14, image 1 of 3 How to Open Your Logitech G502 Hero Mouse: step 14, image 2 of 3 How to Open Your Logitech G502 Hero Mouse: step 14, image 3 of 3
    • At this point, the shells should be fully separated. If they're not, repeat the previous unclipping steps with your spudger.
    • Lift the top shell straight up and remove it, making sure the main mouse cable stays attached to the bottom shell.
    • During reassembly, put the top shell back in place and work your way around the perimeter firmly squeezing the shells together to reengage the clips.
    Ask FixBot
8 other people completed this guide.
Spencer Day
195,932 Reputation
1,243 Guides authored
iFixit Member of iFixit
Staff
123 Members
27,603 Guides authored
1 Guide Comment
G5 and G4 are bound down and I cannot get them freed up.
Wub “Wubba” Wub - Reply Share
Past 24 Hours: 49
Past 7 Days: 395
Past 30 Days: 1,621
All Time: 28,971
