How to Open Your Logitech Ergo M575S
    1. How to Open Your Logitech Ergo M575S, Turn off your mouse: step 1, image 1 of 1
      • Before starting, flip the power switch on the bottom of your mouse down, so it's in the OFF position.
      Ask FixBot
    2. How to Open Your Logitech Ergo M575S, Remove the battery cover: step 2, image 1 of 3 How to Open Your Logitech Ergo M575S, Remove the battery cover: step 2, image 2 of 3 How to Open Your Logitech Ergo M575S, Remove the battery cover: step 2, image 3 of 3
      • Push the battery cover's center tab in and up to remove the cover.
      Ask FixBot
    3. How to Open Your Logitech Ergo M575S, Remove the battery: step 3, image 1 of 3 How to Open Your Logitech Ergo M575S, Remove the battery: step 3, image 2 of 3 How to Open Your Logitech Ergo M575S, Remove the battery: step 3, image 3 of 3
      • Use your fingers to lift the end of the battery and slide it out of its recess.
      • During reassembly, check the sticker in the recess to ensure you insert the battery in the proper orientation.
      Ask FixBot
    1. How to Open Your Logitech Ergo M575S, Remove the trackball: step 4, image 1 of 3 How to Open Your Logitech Ergo M575S, Remove the trackball: step 4, image 2 of 3 How to Open Your Logitech Ergo M575S, Remove the trackball: step 4, image 3 of 3
      • Insert a spudger into the trackball hole on the bottom of the mouse and push the trackball out of its recess.
      Ask FixBot
    2. How to Open Your Logitech Ergo M575S, Heat the feet: step 5, image 1 of 2 How to Open Your Logitech Ergo M575S, Heat the feet: step 5, image 2 of 2
      • The mouse feet cover screws and must be removed to open the mouse.
      • Heat an iOpener and lay it on the mouse feet for one minute to soften the adhesive securing the feet.
      • Alternatively, you can use a hair dryer on the Low heat setting to soften the adhesive.
      • If you're using a hair dryer, only heat the feet a few seconds at a time or you may warp the plastic shell.
      Ask FixBot
    3. How to Open Your Logitech Ergo M575S, Remove the feet: step 6, image 1 of 3 How to Open Your Logitech Ergo M575S, Remove the feet: step 6, image 2 of 3 How to Open Your Logitech Ergo M575S, Remove the feet: step 6, image 3 of 3
      • If you're reusing the feet, be careful not to damage them during removal.
      • Slide the point of a spudger under the end of one of the feet and lift until you can grip it with your fingers.
      • Use your fingers to peel up and remove the mouse foot.
      • If the foot separated from its adhesive, use tweezers to remove any bits from the recess. You'll need to replace any feet that separate from their adhesive.
      Ask FixBot
    4. How to Open Your Logitech Ergo M575S: step 7, image 1 of 3 How to Open Your Logitech Ergo M575S: step 7, image 2 of 3 How to Open Your Logitech Ergo M575S: step 7, image 3 of 3
      • Repeat the process to remove the four remaining feet.
      • If the feet feel stuck, apply more heat and try again.
      Ask FixBot
    5. How to Open Your Logitech Ergo M575S, Remove the case screws: step 8, image 1 of 2 How to Open Your Logitech Ergo M575S, Remove the case screws: step 8, image 2 of 2
      • Use a Phillips screwdriver to remove the five screws securing the two halves of the mouse together:
      • Four 7.8 mm‑long screws
      • One 7.6 mm‑long screw
      Ask FixBot
    6. How to Open Your Logitech Ergo M575S, Separate the mouse halves: step 9, image 1 of 3 How to Open Your Logitech Ergo M575S, Separate the mouse halves: step 9, image 2 of 3 How to Open Your Logitech Ergo M575S, Separate the mouse halves: step 9, image 3 of 3
      • Insert the flat end of a spudger between the two halves of the mouse, near the front.
      • Slide the spudger towards the back of the mouse and gently pry to release the clips securing the two halves.
      Ask FixBot
    7. How to Open Your Logitech Ergo M575S: step 10, image 1 of 3 How to Open Your Logitech Ergo M575S: step 10, image 2 of 3 How to Open Your Logitech Ergo M575S: step 10, image 3 of 3
      • Repeat the process to separate the other side of the mouse.
      • Don't try to fully separate the two halves yet—a ribbon cable still connects them.
      Ask FixBot
    8. How to Open Your Logitech Ergo M575S, Reposition the top half: step 11, image 1 of 3 How to Open Your Logitech Ergo M575S, Reposition the top half: step 11, image 2 of 3 How to Open Your Logitech Ergo M575S, Reposition the top half: step 11, image 3 of 3
      • Gently lift the top half and place it to the left of the mouse so you can access the internals.
      Ask FixBot
    9. How to Open Your Logitech Ergo M575S, Disconnect the top half: step 12, image 1 of 3 How to Open Your Logitech Ergo M575S, Disconnect the top half: step 12, image 2 of 3 How to Open Your Logitech Ergo M575S, Disconnect the top half: step 12, image 3 of 3
      • Use the point of a spudger to gently push up on alternating sides of the interconnect cable locking tab until it clicks into its unlocked position.
      • You should feel the latch pop into the unlocked position. Don't push too far, or the latch may come completely off the connector.
      Ask FixBot
    10. How to Open Your Logitech Ergo M575S: step 13, image 1 of 2 How to Open Your Logitech Ergo M575S: step 13, image 2 of 2
      • Slide the cable straight up and out of its socket.
      Ask FixBot
    11. How to Open Your Logitech Ergo M575S, Remove the top half: step 14, image 1 of 1
      • Remove the top half of the mouse from the bottom half.
      Ask FixBot
Reuse or Recycle—Never put discarded electronic parts in household waste. Visit Logitech Recycling to find your nearest recycling points, including the option to mail back old devices to Logitech for free if there’s no convenient solution in your area. You can also take your e-waste to any R2 or e-Stewards certified recycler. And don’t let good working parts or repaired devices die a slow death in your sock drawer—pass them along to someone who can use them.
Share your experience—Leave a comment here or send your feedback directly to Logitech at repair@logitech.com to help shape future repair guides and product design.
Spencer Day
201,139 Reputation
1,243 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 37
Past 30 Days: 170
All Time: 975
