How to Open Your Logitech C920 Webcam
    1. How to Open Your Logitech C920 Webcam, Prepare your webcam for disassembly: step 1, image 1 of 3 How to Open Your Logitech C920 Webcam, Prepare your webcam for disassembly: step 1, image 2 of 3 How to Open Your Logitech C920 Webcam, Prepare your webcam for disassembly: step 1, image 3 of 3
      • Before you begin, unplug your webcam, close the mounting clip, and remove the privacy shutter.
      Ask FixBot
    2. How to Open Your Logitech C920 Webcam, Remove the screw covers: step 2, image 1 of 3 How to Open Your Logitech C920 Webcam, Remove the screw covers: step 2, image 2 of 3 How to Open Your Logitech C920 Webcam, Remove the screw covers: step 2, image 3 of 3
      • Be careful not to damage the rubber pads or plastic case during this step. Work slowly and don't push hard against the webcam.
      • Push an arm of a pair of angled tweezers under one of the rubber pads on the underside of the webcam.
      • There's a small hole near the center of the back edge (farthest from the lens). Try inserting your tweezers here to prevent damaging the pad.
      • Slide the tweezers farther under the pad and lift to remove it.
      Ask FixBot
    3. How to Open Your Logitech C920 Webcam: step 3, image 1 of 1
      • Repeat the previous step to remove the other pad.
      Ask FixBot
    4. How to Open Your Logitech C920 Webcam, Remove the grille screws: step 4, image 1 of 3 How to Open Your Logitech C920 Webcam, Remove the grille screws: step 4, image 2 of 3 How to Open Your Logitech C920 Webcam, Remove the grille screws: step 4, image 3 of 3
      • Use a Phillips screwdriver to remove the four 4.5 mm‑long screws securing the microphone grilles.
      Ask FixBot
    5. How to Open Your Logitech C920 Webcam, Remove the microphone grilles: step 5, image 1 of 3 How to Open Your Logitech C920 Webcam, Remove the microphone grilles: step 5, image 2 of 3 How to Open Your Logitech C920 Webcam, Remove the microphone grilles: step 5, image 3 of 3
      • Insert an opening tool in the microphone grille seam on the outer edge of the webcam.
      • Slide the opening tool along the seam to release the clips.
      • If you don't feel and hear the clips release, remove the opening tool and try again.
      Ask FixBot
    6. How to Open Your Logitech C920 Webcam: step 6, image 1 of 2 How to Open Your Logitech C920 Webcam: step 6, image 2 of 2
      • Use your fingers to remove the microphone grille.
      Ask FixBot
    7. How to Open Your Logitech C920 Webcam: step 7, image 1 of 3 How to Open Your Logitech C920 Webcam: step 7, image 2 of 3 How to Open Your Logitech C920 Webcam: step 7, image 3 of 3
      • Repeat the process to remove the microphone grille on the other side.
      • During reassembly, put the grille covers in place and squeeze firmly to engage the clips.
      Ask FixBot
    8. How to Open Your Logitech C920 Webcam, Remove the lens cover screws: step 8, image 1 of 3 How to Open Your Logitech C920 Webcam, Remove the lens cover screws: step 8, image 2 of 3 How to Open Your Logitech C920 Webcam, Remove the lens cover screws: step 8, image 3 of 3
      • Use a Phillips screwdriver to remove the eight 8.0 mm‑long screws on the outer edges securing the lens cover.
      Ask FixBot
    9. How to Open Your Logitech C920 Webcam, Remove the lens cover: step 9, image 1 of 2 How to Open Your Logitech C920 Webcam, Remove the lens cover: step 9, image 2 of 2
      • Use your fingers to lift and remove the lens cover.
      Ask FixBot
    10. How to Open Your Logitech C920 Webcam, Fully open the hinges: step 10, image 1 of 2 How to Open Your Logitech C920 Webcam, Fully open the hinges: step 10, image 2 of 2
      • Tilt the main body of the webcam so its hinges are fully open.
      Ask FixBot
    11. How to Open Your Logitech C920 Webcam, Remove the hinge screws: step 11, image 1 of 2 How to Open Your Logitech C920 Webcam, Remove the hinge screws: step 11, image 2 of 2
      • Use a Phillips screwdriver to remove the five screws securing the hinge mechanism:
      • Four 4.8 mm‑long screws
      • One 6.0 mm‑long screw
      Ask FixBot
    12. How to Open Your Logitech C920 Webcam, Remove the mounting clip: step 12, image 1 of 3 How to Open Your Logitech C920 Webcam, Remove the mounting clip: step 12, image 2 of 3 How to Open Your Logitech C920 Webcam, Remove the mounting clip: step 12, image 3 of 3
      • Tilt the mounting clip so the hinges lift away from the webcam.
      • Slide the hinges out of their recess and remove the mounting clip.
      • During reassembly, make sure both hinges are fully open before sliding them into place.
      Ask FixBot
    13. How to Open Your Logitech C920 Webcam, Remove the rubber spacers: step 13, image 1 of 3 How to Open Your Logitech C920 Webcam, Remove the rubber spacers: step 13, image 2 of 3 How to Open Your Logitech C920 Webcam, Remove the rubber spacers: step 13, image 3 of 3
      • Use tweezers or your fingers to remove the two circular rubber spacers from the outer edges of the webcam.
      Ask FixBot
    14. How to Open Your Logitech C920 Webcam, Remove the inner housing: step 14, image 1 of 3 How to Open Your Logitech C920 Webcam, Remove the inner housing: step 14, image 2 of 3 How to Open Your Logitech C920 Webcam, Remove the inner housing: step 14, image 3 of 3
      • Use an opening tool to gently pry up and unclip the left, right, and bottom edges of the plastic inner housing.
      • During reassembly, slide the housing into place and press gently around the perimeter to engage the clips.
      Ask FixBot
    15. How to Open Your Logitech C920 Webcam: step 15, image 1 of 2 How to Open Your Logitech C920 Webcam: step 15, image 2 of 2
      • Remove the inner housing.
      Ask FixBot
    16. How to Open Your Logitech C920 Webcam, Your webcam is open: step 16, image 1 of 1
      • Your webcam is now open, with the internals accessible.
      Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers Community for troubleshooting help.
Reuse or Recycle—Never put discarded electronic parts in household waste. Visit Logitech Recycling to find your nearest recycling points, including the option to mail back old devices to Logitech for free if there’s no convenient solution in your area. You can also take your e-waste to any R2 or e-Stewards certified recycler. And don’t let good working parts or repaired devices die a slow death in your sock drawer—pass them along to someone who can use them.
Share your experience—Leave a comment here or send your feedback directly to Logitech at repair@logitech.com to help shape future repair guides and product design.
Spencer Day
201,076 Reputation
1,243 Guides authored
0 Guide Comments
Past 24 Hours: 9
Past 7 Days: 38
Past 30 Days: 94
All Time: 599
