How to Open Sony VAIO PCG-F580
    1. How to Open Sony VAIO PCG-F580, How to Open Sony VAIO PCG-F580: step 1, image 1 of 3 How to Open Sony VAIO PCG-F580, How to Open Sony VAIO PCG-F580: step 1, image 2 of 3 How to Open Sony VAIO PCG-F580, How to Open Sony VAIO PCG-F580: step 1, image 3 of 3
      • On the side with the audio ports, there is a Philips screw. Unscrew it.
      • Push the loose plastic piece, this will loosen the daughterboard from the main case.
      Ask FixBot
    2. How to Open Sony VAIO PCG-F580, Taking Off the Daughterboard: step 2, image 1 of 3 How to Open Sony VAIO PCG-F580, Taking Off the Daughterboard: step 2, image 2 of 3 How to Open Sony VAIO PCG-F580, Taking Off the Daughterboard: step 2, image 3 of 3
      • Open the lid, and pull up on the daughterboard enough to see the ribbon cable.
      • Pull up on the ribbon cable to release it. Don't worry, if you pull it straight up, there will be no damage.
      • Set the daughterboard to the side for now.
      Ask FixBot
    3. How to Open Sony VAIO PCG-F580, The Keyboard: step 3, image 1 of 3 How to Open Sony VAIO PCG-F580, The Keyboard: step 3, image 2 of 3 How to Open Sony VAIO PCG-F580, The Keyboard: step 3, image 3 of 3
      • Unscrew the Philips screw at the top of the keyboard.
      • Remove the ribbon cable by pulling up on the plastic tabs on either sides of the socket with tweezers, then lifting it straight out.
      • Lift the keyboard up at an angle, towards the screen.
      • Note: If you hear what sounds like peeling, that's normal.
      Ask FixBot
CI S
660 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 13
Past 30 Days: 71
All Time: 388
