How to Make a Hockey Stick Longer
  1. How to Make a Hockey Stick Longer, How to Make a Hockey Stick Longer: step 1, image 1 of 2 How to Make a Hockey Stick Longer, How to Make a Hockey Stick Longer: step 1, image 2 of 2
    • Procure an extender that will fit your stick.
    • Your stick should say if it is a junior or senior stick; get the corresponding extender.
    Ask FixBot
  2. How to Make a Hockey Stick Longer: step 2, image 1 of 1
    • Remove the tape on the end of the stick.
    Ask FixBot
  3. How to Make a Hockey Stick Longer: step 3, image 1 of 1
    • Remove the plug/stopper from the end of the stick using a spudger.
    Ask FixBot
  4. How to Make a Hockey Stick Longer: step 4, image 1 of 2 How to Make a Hockey Stick Longer: step 4, image 2 of 2
    • Heat the glue on the extender with a hair dryer for approximately four minutes.
    • The glue should look wet and sticky.
    Ask FixBot
  5. How to Make a Hockey Stick Longer: step 5, image 1 of 1
    • Heat the end of the stick up where you will insert the extender for about five minutes.
    Ask FixBot
  6. How to Make a Hockey Stick Longer: step 6, image 1 of 3 How to Make a Hockey Stick Longer: step 6, image 2 of 3 How to Make a Hockey Stick Longer: step 6, image 3 of 3
    • Insert the extender into the butt of the stick.
    • You can flip the stick and use the ground to help get the extender in all the way since it is a snug fit.
    • You can use the hair dryer as needed to heat the glue and the stick up more if you are having a hard time getting the extender in.
    Ask FixBot
  7. How to Make a Hockey Stick Longer: step 7, image 1 of 1
    • Wipe the excess glue where the stick and extender join with a rag or napkin.
    • Allow the glue to dry for about 10 minutes.
    • You can also go onto the next step if the stick is cooled down to normal temperature.
    Ask FixBot
  8. How to Make a Hockey Stick Longer: step 8, image 1 of 2 How to Make a Hockey Stick Longer: step 8, image 2 of 2
    • Tape the top of the stick or install grip tape (optional).
    Ask FixBot
Finish Line
Izzy
181 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 42
All Time: 394
