How to Lubricate a Zipper
    1. How to Lubricate a Zipper, How to Lubricate a Zipper: step 1, image 1 of 3 How to Lubricate a Zipper, How to Lubricate a Zipper: step 1, image 2 of 3 How to Lubricate a Zipper, How to Lubricate a Zipper: step 1, image 3 of 3
      • Lay your garment on a table.
      • If you can, unzip the zipper.
      • If you can't move the slider, just work around it.
      • Using the brush located on top of the Zip Care bottle, or simply using a nylon brush, work the dirt and debris off of the zipper coil or the teeth of the zipper.
      Ask FixBot
    2. How to Lubricate a Zipper: step 2, image 1 of 2 How to Lubricate a Zipper: step 2, image 2 of 2
      • Pinch the slider in your fingers, so that you can see into the area where the coil rests.
      • Use the brush to free any dirt or debris caught inside the slider.
      Ask FixBot
    3. How to Lubricate a Zipper: step 3, image 1 of 3 How to Lubricate a Zipper: step 3, image 2 of 3 How to Lubricate a Zipper: step 3, image 3 of 3
      • Place a paper towel behind the zipper.
      • To prevent messes, make sure that the paper towel is touching the underside of the teeth or coil.
      Ask FixBot
    4. How to Lubricate a Zipper: step 4, image 1 of 3 How to Lubricate a Zipper: step 4, image 2 of 3 How to Lubricate a Zipper: step 4, image 3 of 3
      • Twist open the Zip Care.
      • Gently squeeze the bottle as you slide the brush along the teeth or coil of the zipper to apply the lubricant.
      • Repeat this on both sides of the zipper teeth or coil.
      Ask FixBot
    5. How to Lubricate a Zipper: step 5, image 1 of 2 How to Lubricate a Zipper: step 5, image 2 of 2
      • Fold the paper towel over and dab any excess lubricant off the zipper.
      Ask FixBot
    6. How to Lubricate a Zipper: step 6, image 1 of 2 How to Lubricate a Zipper: step 6, image 2 of 2
      • Zip and unzip the zipper a few times to work the lubricant in between the teeth or coil.
      Ask FixBot
Finish Line
6 other people completed this guide.
Brittany McCrigler
91,067 Reputation
142 Guides authored
iFixit Member of iFixit
Staff
123 Members
85,826 Guides authored
1 Guide Comment
Hi Brittany, I’m hoping you have an answer for my favourite purse. The zipper is frozen due to the remnant of a plastic bag I put in my purse. Please advise!
Clair - Reply Share
Past 24 Hours: 4
Past 7 Days: 47
Past 30 Days: 215
All Time: 122,469
