How to Lengthen a Necklace Chain
  1. How to Lengthen a Necklace Chain, How to Lengthen a Necklace Chain: step 1, image 1 of 1
    • Measure and determine the desired length of jewelry chain that you want to add.
    • Place a piece of tape to mark where you want to cut.
    Ask FixBot
  2. How to Lengthen a Necklace Chain: step 2, image 1 of 1
    • Cut the extender chain with wire cutters/scissors at the tape marker.
    Ask FixBot
  3. How to Lengthen a Necklace Chain: step 3, image 1 of 1
    • Look at your jump ring. If there is no opening in the jump ring, carefully cut the ring yourself with scissors.
    Ask FixBot
  4. How to Lengthen a Necklace Chain: step 4, image 1 of 1
    • Use jewelry pliers to open the jump ring at one end of the extender chain and one end of the jewelry chain.
    Ask FixBot
  5. How to Lengthen a Necklace Chain: step 5, image 1 of 1
    • Connect one end of the extender chain to the jump rings.
    • Repeat the process by attaching one end of the jewelry chain to the same jump ring the extender chain is on.
    Ask FixBot
  6. How to Lengthen a Necklace Chain: step 6, image 1 of 1
    • With the jewelry pliers, carefully squeeze the jump ring shut, ensuring both the extender chain and jewelry chain remain securely attached to it.
    Ask FixBot
  7. How to Lengthen a Necklace Chain: step 7, image 1 of 1
    • Make sure that the extender chain's closure is secure and won’t open or come loose during wear. If everything seems correct, you are ready to wear it!
    Ask FixBot
Finish Line
Faith Low
145 Reputation
1 Guide authored
UC Davis, Team 2-3, Whithaus Spring 2024 Member of UC Davis, Team 2-3, Whithaus Spring 2024
UCD-WHITHAUS-S24S2G3
4 Members
2 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 32
All Time: 566
